Understand Momentum, Force and Impulse
Momentum is defined as the product of an object's mass and its velocity, while impulse represents the change in momentum resulting from a force applied over time. When a force is applied to an object, it causes acceleration, which can increase or decrease momentum depending on the direction of the force relative to the object's motion. The change in momentum equals the impulse delivered to the object, which is calculated as the integral of force over time. Real-world examples, such as the differing accelerations of a sports car versus a sedan, illustrate how greater force results in greater impulse and momentum. Understanding these concepts is crucial for analyzing motion and collisions in physics.
Aman Trivedi
Hi everyone! I've been getting confused with Momentum, Force and Impulse. From my understanding force when applied on object helps it gain momentum, the higher the force applied the higher the acceleration therefore more the momentum. And according to Sir Isaac Newton's first law of motion, the object that the force was applied on will keep moving, therefore won't change its momentum until another force slows it down. Once it does slow the object down the change in momentum would equal to the impulse applied on the object. Therefore the impulse would determine the objects momentum post the collision? Am I right? If not could you please give me a very simplified explanation on why impulse and momentum differ?
Momentum is (non-relativistic physics)
$$\vec{p}=m \vec{v}.$$
Force is
$$\dot{\vec{p}}=\vec{F},$$
and impulse is the change of momentum between two times
$$\vec{p}(t_2)-\vec{p}(t_1)=\int_{t_1}^{t_2} \mathrm{d} t \dot{\vec{p}}(t)=\int_{t_1}^{t_2} \mathrm{d} t \vec{F}.$$
Force is
I understand the relationship, but it would help if you could give me a example in terms of a real world
Situation where momentum and impulse come into play... Thanks (:
Yes, the change in an object's momentum equals the impulse (force x time-interval) delivered to it by the force.
Analogously, the change in an object's kinetic energy equals the work (force x distance) delivered to it by the force. (assuming potential energy doesn't come into play)
(and in either case, "force x whatever" must be understood to mean an integral if the force is not constant.)
Momentum is the product of mass and velocity. Acceleration is the result of applying a force to a mass. What happens when an object is moving in the opposite direction that the applied force points? Well, it would lose momentum instead, not gain it. So a net applied force doesn't lead to momentum, it leads to a change in momentum.
Stick to the basic definitions and you can't go wrong. Momentum is a quantity that is the product of an objects mass times its velocity. Impulse is a change in the momentum and is equal to the integral of the applied force over time.
An obvious example would be rockets, but you could also imagine being in a car that is accelerating. A sports car with 500 horsepower can apply a larger force to the ground than a sedan with 100 horsepower. So if both cars floor their gas pedals and accelerate for the same amount of time, the impulse of the sports car is larger than the impulse of the sedan. The sports car gains more velocity and momentum over that time than the sedan.
Likes Kia Neves
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
