Wheel attached to a rope falls
In summary: But the rope is attached to the inner hoop, not the outer hoop. I think the string will unravel and the wheel will rotate about the center of mass.That's interesting. I had assumed that the rope would just unwind from the inner hoop and the hoop would drop without noticeable rotation. But I think you are right, the result will be as you describe.That means that the rope tension will be directed along the rope, not radially outward. That's an important point. I think you should write out the equations for the motion of the center of mass of the wheel.I think you will find the motion is not simple harmonic, but more like a damped harmonic motion.Also, I think that in this problem
  • #36
$$\ddot\theta=-\frac{r\dot\theta^2+2\dot s\dot\theta+g\sin\theta}{s}$$
Since i know that at the start the wheel is left from stand still ##\ddot\theta(t=0)=0##
Why do i need the third derivative ##\frac{d^3 \theta}{dt^3}##? it doesn't have any physical meaning, the acceleration is the last
TSny said:
Continue this until you can see what all of the time derivatives of θ\theta will be at t=0t = 0.
I know the velocity, ##\dot\theta(t=0)=0##, and the acceleration ##\ddot\theta(t=0)=0##, what does it help if later it swings?
  • #37
If we assume that the function ##\theta(t)## has a Taylor expansion of the form ##\theta(t) = \theta(0) + \dot{\theta}(0)t + \frac{1}{2!} \ddot{\theta}(0) t^2+ \ldots##
what would ##\theta(t)## be if ##\theta## and all time derivatives of ##\theta## are zero at ##t = 0##?
  • #38
If the previous argument is not satisfactory, then you can appeal to uniqueness theorems of systems of differential equations as mentioned in post #11. You now have the differential equations that the system must satisfy and you have the initial conditions ##s(0) = s_0##, ##\dot{s}(0) = \theta(0) = \dot{\theta}(0) = 0##. If you find one solution to the differential equations that satisfies these initial conditions, then it is the only solution. You can easily find a solution where ##\theta(t) = 0## for all ##t##.
  • #39
$$\frac{d^3 \theta}{dt^3}=-\frac{s(2r\dot\theta\ddot\theta+2\dot\theta\ddot s+2\dot s\ddot\theta+g\dot\theta\cos\theta)-(r\dot\theta^2+2\dot s\dot\theta+g\sin\theta)\dot s}{s^2}$$
$$\frac{d^3 \theta}{dt^3}(t=0)=0$$
Since all members in the numerator include θ or ##\dot\theta## all the higher derivatives will include at least ##\dot\theta## which, at t=0 are 0, so all higher derivatives will be 0 at t=0.
  • #40
Yes. This strongly suggests that ##\theta## will remain zero. However, there are examples of functions where all derivatives are zero at a point yet the function is not constant. See https://en.wikipedia.org/wiki/Flat_function
  • #41
TSny said:
You can easily find a solution where ##\theta(t) = 0 ## for all t.
I don't know how to solve differential equations, not even one alone, so how will i find a solution for two?
  • #42
OK. By the uniqueness theorem, we just need to find any solution. It will then be the only solution. So, try to find a solution where ##\theta## is always zero. Can you satisfy the two differential equations with this assumption?
  • #43
The first equation:
$$mg\sin\theta=-m(r\dot\theta^2+s\ddot\theta+2\dot s\dot\theta)$$
The second:
$$\frac{I_c+mr^2}{r}\ddot s+2ms\dot s\dot\theta+[I_c+m(s^2+r^2)]\ddot\theta=mg(r\cos\theta-s\cdot \sin\theta)$$
If i take ##\theta(t)=0## the first equation is satisfied but the second becomes:
$$\frac{I_c+mr^2}{r}\ddot s=mgr$$
  • #44
OK. The second equation gives you information about the acceleration of the disk as it moves straight down. You can then get the velocity and position of the disk at any time.
  • #45
Yes, correct:
$$M=I_A\alpha,\quad \alpha r=\ddot s$$
$$\frac{I_c+mr^2}{r}\ddot s=mgr\quad \rightarrow\quad I_A\ddot s=mgr^2$$
$$I_A\alpha r=mgr\cdot r$$
  • #46
Looks good.
  • #47
I have no more questions about this problem, i thank you TSny and Haruspex very much!
