Why AM wave is multiplication of carrier and message signal?
The discussion centers on the nature of amplitude modulation (AM) waves, specifically comparing two types of modulation: one that includes sidebands and one that does not. Participants explore the implications of these different approaches in the context of communication systems, particularly regarding the transmission of information.
  • Post 1 introduces two waveforms, A and B, both amplitude modulated, and questions why waveform A is preferred despite waveform B having no sideband frequencies and a shorter bandwidth.
  • Post 2 argues that waveform B does not facilitate the up-conversion of the signal for transmission, suggesting that sidebands are necessary to convey information effectively.
  • Post 3 seeks clarification on how sidebands carry information, indicating a lack of familiarity with the concept among some participants.
  • Post 4 explains that sidebands are essential as they contain the information being transmitted, referencing Fourier decomposition and the spectral representation of modulated signals.
  • Post 5 expresses gratitude for the clarification provided, indicating a growing understanding of the topic among participants.
Participants exhibit differing views on the necessity of sidebands in amplitude modulation, with some arguing for their importance in information transmission while others question the efficiency of different modulation types. The discussion remains unresolved regarding the optimal approach to modulation.
There are assumptions regarding the familiarity with Fourier analysis and the technical details of modulation that may not be shared by all participants. The discussion also highlights the dependence on specific definitions of modulation types and their implications for bandwidth and information transmission.
Dark_Capacitor
Let A= (sin(x) * sin(100x)) + sin(100x).; modulation index is 1;
Let B= (sin(x) + sin (100x));
Both of these waves have same frequency and both are amplitude modulated.
When passed through an envelope detector, both will give message signal.
And B have an advantage of not having any sideband frequency. Thus allowing bandwidth to be very short.
Then why we use wave A type modulation not B. All the ssb and suppressed carrier wave also use technique A, why not B?
B is not an up-conversion of the signal you want to transmit. In other words, let's say you want to transmit a 100 kHz signal, you do not want to amplify it an send into the antenna... what you want to do is to up-convert it in frequency, and then send an electromagnetic wave of frequency e.g. > 100 MHz. If your high frequency carrier does not have sidebands, you are not transmitting informations with it.
Thank you matteo137 for replying. I'm new to communication systems. Can you tell how exactly side bands carry information? All I know is that the envelope of the carrier wave has the message signal.
The sidebands carry information because they ARE the information.
Think about the Fourier decomposition of the signal (hoping you are familiar with it).
Let's say your "information" is a 1 KHz signal, so the spectrum of this signal is a dirac-delta at that frequency. When you modulate a carrier (e.g. 100 MHz) with this signal, the spectrum of the modulated carrier is a dirac-delta at 100 MHz with two symmetric sidebands at +- 1 KHz (see picture). This shows you that when you use a carrier to transmit information, what you actually care are ONLY the sidebands, and this is true also for FM modulations.
There are even example of transmission techniques which suppress the carrier and one of the two sidebands before transmitting the signal through air, in such a way that you only send one useful sideband. (of course the receiver has to know the frequency of the carrier, and have a stable oscillator)
Picture AM spectrum:
http://en.wikipedia.org/wiki/Amplitude_modulation#mediaviewer/File:AM_spectrum.svg
Thanks man. You cleared up many things. And I familiar with Fourier analysis:oldwink:
  • · Replies 19 ·
  • · Replies 41 ·
  • · Replies 24 ·
