Why can we assume the temperature of a fluid is T_sat?
In the discussion, the temperature of R134a in a rigid container at 100 kPa is assumed to be T_sat because the specific volume of 1.1 L/kg falls between the specific volumes of saturated liquid and saturated vapor at that pressure. The calculated temperature of -26.37°C is confirmed by referencing the saturated R134a table. If the quality calculated using the equation v = v_f + x(v_fg) exceeds one, it indicates that the substance is indeed a vapor. The conversation emphasizes the importance of using specific volume and saturation tables to determine the state of the fluid accurately. Understanding these principles is crucial for thermodynamic analysis in engineering applications.
zachdr1
For example, in this question..
A 11 L rigid container contains 10-kg of R134a at 100kPa. Determine the temperature and total enthalpy in the container.
Why can we just assume that the temperature we're looking for is T_sat, how do we know this isn't a compressed liquid? How do we know it isn't a superheated vapor?
The answer (-26.37) is found by looking it up in the saturated R134a table.
Science news on Phys.org
The specific volume of your sample is 1.1 L/kg = 0.0011 m^3/kg. Look in your tables and see if you find any compressed liquid or superheated vapor with this specific volume at 100 kPa. But it does lie between the specific volume of saturated liquid and the specific volume of saturated vapor at 100 kPa.
Ohhh okay that makes sense. Thank you.
This doesn't relate the the original problem I posted, but what happens if when using the equation v=v_f + x(v_fg) with the values from the saturated tables, I get a quality that is greater than one? Does that mean that the substance is actually a vapor or what?
Sure. In fact you should be able to see that from the superheated tables.
I was watching a Khan Academy video on entropy called: Reconciling thermodynamic and state definitions of entropy. So in the video it says: Let's say I have a container. And in that container, I have gas particles and they're bouncing around like gas particles tend to do, creating some pressure on the container of a certain volume. And let's say I have n particles. Now, each of these particles could be in x different states. Now, if each of them can be in x different states, how many total...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
