Why can't I substitute a Laplace transform into an integration?
hyphagon
Hi, I was given the attached question and have given my wrong attempt at the answer. I know how to work the answer out (also shown) but I would like to know why my first attempt is wrong.
Many Thanks
First, you calculated u'(t) incorrectly. Second, when you said v=2/s2, you used the definite integral of dv/dt. You need to use the indefinite integral. You can't get rid of the t dependence.
Yup, I integrated it by mistake. That now makes it equal zero incidentally.
Awesome, Thanks for for that. Makes sense now.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
