Why Do Different Methods Give Different Answers to j \cdot {-j}?
  • Thread starter mbrmbrg
8 replies · 2K views · last reply
mbrmbrg
Nice, simple, straighforward problem:
[itex]j \cdot {-j}[/itex]
Difficulty: I solved it two ways and got two answers.
[itex]\vec{a} \cdot \vec{b}=ab\cos\phi[/itex]
So in this case, I should get [tex]j \cdot {-j}=(1)(-1)(cos(180^o))=(1)(-1)(-1)=1[/itex]<br /> <br /> However, using the formula [itex]\vec{a} \cdot \vec{b}=a_{x}b_{x}+a_{y}b_{y}+a_{z}b_{z}[/itex], I got [itex]j \cdot {-j}=a_{y}b_{y}=(1)(-1)=-1[/itex]<br /> <br /> Can anyone tell me why?[/tex]
[tex] <br /> Recall that the dot product is:<br /> [tex]\vec A \cdot \vec B = |\vec A| |\vec B| \cos \theta_{AB}[/tex]<br /> <br /> let [itex]\vec A = (0,-1,0)[/itex]<br /> [tex]A=|\vec A| = \sqrt{(0)^2 +(-1)^2 +(0)^2}[/tex]<br /> <br /> What is [itex](-1)^2[/itex] :)[/tex]
Neither my book nor my professor mentions the absolute value thing. I guess that's completely implied, though, because the negative sign has to do with direction, not magnitude.
Thank you so much!
[tex]|\vec A|[/tex] means magnitude of [tex]\vec A[/tex], which is a scalar and is given by the square root of the sum of the squares of the magnitudes of the component vectors. [tex]|\vec{a}|\,=\,\sqrt{a^2_x+a^2_y+a^2_z}[/tex]
One could also use the fact that -j * j = - (j * j) = - (1) = -1, where I use * to mean the dot product.
Presumable j is a unit vector (0, 1, 0).
Back to the OP:
[tex]j \cdot {-j}=(1)(1)(cos(180^o))=(1)(1)(-1)=-1[/tex]
I think basically your mistake lies in your calculation of the modulus(magnitude) of -j which is 1 not -1.For use in the formula a*b=abcos#
where * means dot product
a/b mean the magnitudes(moduli) of a & b
How is that derived/proven?
The dot product operation has an associative property, that says:
[tex](k \vec A) \cdot \vec B = k (\vec A \cdot \vec B)[/tex]
Where [itex]k[/itex] is a scalar, and [itex]\vec A, \,\, \vec B[/itex] are vectors.
Riiiiiight...
I've got to start consistently thinking of a negative sign as -1 multiplied by what follows, don't I.
Thanks!
mbrmbrg said:
Riiiiiight...
Thanks!
I remember how much grief that used to give me :smile:
