Why do F- and OH- have negative S values?
  • Thread starter Thread starter MaddenDude
    Negative
F- and OH- ions exhibit negative standard entropy (S) values due to their unique thermodynamic properties, which are often relative to the arbitrary zero point assigned to the formation of H+ ions. This context is crucial as entropy values can vary based on the phase of matter, with the discussion primarily focusing on aqueous solutions. The negative S values for these ions suggest that they have lower entropy compared to other species, which typically have positive values. This phenomenon is not exclusive to F- and OH-, as other ions may also display negative entropy values under specific conditions, but they are among the most commonly referenced examples in thermodynamic studies. Understanding these values requires a grasp of the underlying principles of thermodynamics and the reference points used in calculations.
MaddenDude
Why do F- and OH- have negative S values? (Entropy)
And are they the only ones with negative S values?
Chemistry news on Phys.org
The question isn't too meaningful without a context: aqueous? gas phase? Homework?
aqueous; its not homework, I'm just curious. In my book, all the S values are positive except those two, I'm just wondering why.
Snoop around in the discussion of thermodynamic properties of ions a little more --- you'll find that they are relative to arbitrarily assigned zero values for H+ formation.
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
