Why do people write lines ax + by = c instead of y = mx + b?
  • Thread starter Thread starter flyingpig
    Lines
flyingpig
Yeah that always confuses me, why do books sometiems refer lines implicitly?
No idea why they do it, but one good reason to write it that way is because there's no "privileged" coordinate in a plane.
Think about the equation for a circle -- it only gets confusing when you try to define y as a "function" of x or vice-versa.
ax + by = c is a more general form than y = mx + b. That's probably why it is called the "general form". Not all straight lines can be written in the y = mx + b form. Try to write the vertical line through (5,0) that way.
I write the equation of the line y=mx+c...
It's more general, when you come on to planes which are written ax+by+cz=d, it's a nice generalisation of the equation of the line.
And how do you deal with the issue that LCKurtz brought up?
I was attempting some humour there...
But the point is well said, i normally just write x=k for vertical lines.
Which, of course, can be given from the general form of the line by letting b=0 and then letting k=c/a.
The symmetry becomes even stronger if you use projective coordinates -- i.e. if Z is nonzero, then (X:Y:Z) refers to the point (X/Z, Y/Z). In these coordinates, the equation of a line is most conveniently written as:
aX + bY + cZ = 0​
(quick exercise: prove that if (X:Y:Z) and (X':Y':Z') define the same affine point, then either both points satisfy the above equation, or neither does)
(aside: Z=0 corresponds to the "points at infinity" on the "projective plane")
