Why do the upper and lower potions cancel the magnetic field?
The discussion centers on why the magnetic fields from the upper and lower portions of a solenoid cancel each other out, resulting in a weak external magnetic field. The Bio-Savart Law is referenced to analyze the contributions of current elements in the solenoid. It is noted that the direction of the magnetic field generated by the upper current elements is opposite to that of the lower ones at exterior points. This opposition leads to a reduction in the net magnetic field outside the solenoid. The explanation highlights the importance of considering the orientation and position of current elements in understanding magnetic field behavior.
anonymousphys
Referring to the magnetic field in a solenoid:
"The field at exterior points is weak because the field due to current elements on the upper potions tends to cancel the field due to current elements on the lower portions"
Bio-Savart Law
This is suppose to to explain why the magnetic field outside a solenoid is zero, but I am not sure why. When I draw the components of the current creating the magnetic field outside a solenoid, they do not cancel out. Is my reasoning incorrect?
In a coil, if the current in the upper current element on the top is going into the page, the field in the exterior point is towards right. The current in the lower current element is coming out of the page. The field due to this current element at the same exterior point is towards left. So the net field at that point is reduced.
