Why does heat reflect sunlight? (ie: mirages)
  • Thread starter Thread starter baywax
    Heat Sunlight
Mirages occur due to the refraction of light caused by temperature gradients in the air. As heat causes air to rise, it creates layers of varying density, which affects the refractive index. This bending of light occurs when it transitions between different densities, leading to a visual distortion. The phenomenon is commonly observed in hot environments, such as deserts, where the ground temperature significantly influences air density. Understanding that it is the air, not heat itself, that refracts light clarifies the nature of mirages.
baywax
The title of this thread is all I have to ask about this. You've seen mirages, if they are caused by light reflecting off heat I am wondering why this takes place. Thank you.
Science news on Phys.org
Heat causes air to rise which causes a gradient (a progression) in the density of air with height. This causes a gradient in the refractive index of the air, and that (the change in refractive index) bends the light.
Usually in hot desert, because of the hotness of the sand the density of the air which is close to it decreases and as we go higher/upper the density of air relatively increases so we can imagine them as layers.(as the pic has shown)
mirage.jpe
As we know that light changes its direction and speed when it travels from one dense medium to another dense medium, when this bend exceed the critical angel, it starts following the laws of reflection . . . and the reflection bends again and reaches to our eye . . . and thn we call it MIRAGE
Ah, thank you! I realized after posting that it was the air rather than the heat doing the reflecting. Thanks again!
I hate to be a stickler, but heat doesn't reflect sunlight; it refracts it. The air bends the light ray's path. Both sadaf2605 and cepheid are completely correct with their explanations. I just thought I point out that triviality.
My mistake, refracts. Thank you.
Problem: You’re an Uber driver with a Tesla Model 3. Today’s low: 30F, high: 65F. You want to reach a USD$ profit target in the least number of hours, but your choices could have added cost. Do you preheat the battery only when you are headed to the charging station (to increase the charging rate by warming the battery — however the battery might not be “warm enough” when your reach the charger and thus slower charging rates), or do you always “navigate to the charger” the entire day (which...
