Why increasing the mass flow of steam increases its temperature
Increasing the mass flow rate of steam in a tube leads to higher temperature and pressure due to the relationship between mass flow, pressure, and saturation temperature. As more steam enters the system, the pressure rises, necessitating an increase in saturation temperature to maintain equilibrium. Additionally, the thermal mass and kinetic energy associated with the increased flow contribute to the overall temperature rise. The discussion highlights the interplay between mass flow, pressure, and temperature in steam systems. Understanding these dynamics is crucial for efficient steam management in engineering applications.
sanka
Maybe I'm over-analysing this but if we take a simple example of a tube within which steam is flowing. Why does the temperature (and pressure) of the steam increase as the mass flow rate is increased? Is it simply because as more mass is added in the flow, the pressure within the system increases and as a result, the saturation temperature must also increase?
Or is the addition of thermal mass and the higher kinetic energy associated with it responsible in some way for the temperature increase?
I feel I'm over-thinking a straighforward concept but hopefully someone can clarify this.
All views are appreciated!
Cheers.
Increase where?
Relative to what?
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
