Why Is My Calculation of the Net Electric Field Incorrect?
The discussion revolves around calculating the net electric field at a specific point on the x-axis due to two uniformly charged spheres, one positive and one negative. The user initially calculated the electric field at the origin correctly but struggled with the field at x = R/2. Clarification was provided that for points inside a charged sphere, the electric field depends only on the charge within that radius, while fields from external charges cancel out. Ultimately, the user resolved their confusion with the help of this insight. Understanding the behavior of electric fields inside and outside charged spheres is crucial for solving such electrostatic problems.
Brianjw
I'm stuck on a Electrostatic problem which I just don't seem to get.
The left-hand sphere has a positive charge Q and the right-hand sphere has a negative charge -Q. Charge is distibuted uniformly over each of two spherical volumes with radius . One sphere of charge is centered at the origin and the other at x = 2R
Find the magnitude of the net electric field at the point on the x-axis.
I did the first part already where it wanted the field at the orgin which was simple:
Q/(4*pi*epislon_0*(2R)^2)
but if I try the same method for this one it doesn't seem to work. I wanted to add them together I tried:
Q/(4*pi*epislon_0*(.5R)^2) + Q/(4*pi*epislon_0*(3R/2)^2)
but doesn't like it.
Thanks
find the field where?
You're going to have to be clearer as to what the problem is. Where are you trying to find the field?
Err sorry. It wants me to find the E-field at the Point X=R/2.
Let me put up a picture to help:
http://mp.pearsoncmg.com/probhtml/yf.Figure.22.64.jpg
So I found that the E-field at Point X=0 is:
E = Q/(4*pi*epsilon_0*(2R) ^2 sicne the point is at the center of the first sphere its field doesn't matter, you just use the 2nd sphere which is 2R away to solve it.
I've used this method for other parts of the problem as well. Where I just the two E-fields together to get the right answer. I think there must be something difference since the E-field lies inside one of the spheres.
OK, it looks like you are trying to find the field at x = R/2.
You know how to find the field due to a uniform sphere of charge for all points outside the sphere (r > R). But what is the field for r < R? Hint: The field at a distance x from the center depends only on the charge for r < x. The field at x due to charges at r > x cancels out.
Nm, I got it, thanks for the tip.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
