Why is the electric field inside a conductor zero?
In static equilibrium, the electric field inside a conductor is zero because free-moving charges within the conductor redistribute themselves to cancel any internal electric field. If an electric field were present, it would cause the charges to move until they reach a state where the field is neutralized. Consequently, any excess charge accumulates on the surface of the conductor. This principle is similar to how gravitational forces behave within a sphere, where forces from different sections cancel each other out. Thus, the absence of an electric field inside a conductor is a fundamental characteristic of electrostatics.
Timebomb3750
Why is the electric field, in static equilibrium, equal to zero.
The only way I can see why is to picture that there was an electric field inside a conductor. The field would cause the electrons to move freely inside the conductor. This movement of electrons would cancel out the electric field.
That's my two cents. I'm sure I could expand on this more, but I'm confused because I'm having a really hard time trying to picture this in my head.
You can also show this the same way you show that the gravitational force inside a sphere is 0. Given a point, P, inside the sphere, take a small section of surface area on the surface of the sphere and draw a line from every point in that section through P to the other side of the sphere. Note that the area will be directly proportional to the square of the distance from P and since the force is inversely proportional to the square of the distance, the force from the two sections cancel.
Yes, that's the basic idea.
In a conductor charge is (relatively) free to move. If there were an electric field within a conductor, charges would move. They would move in such a way and to such locations so as to cancel that field.
As a result, any excess local charge can only reside on the surface of a conductor under conditions of equilibrium.
