Why is the Electric Field Zero at the Center of a Charged Ring?
The electric field at the center of a charged ring is zero due to the uniform distribution of charge around it. This configuration can be likened to a hollow sphere, where excess charge resides on the surface, resulting in no electric field within. The concept of electrostatic equilibrium applies, as the charges are balanced and do not create an internal field. A Gaussian surface inside the ring confirms that the net electric flux and electric field are zero, as there is no net charge enclosed. Therefore, the electric field at the center of a charged ring is indeed zero.
mike115
A circular ring of charge of radius b has a total charge q uniformly distributed around it. The magnitude of the electric field at the center of the ring is:
[Answer: 0]
From the problem, do you just assume that the circular ring is a conductor? And since the charge is uniformly distributed, the conductor is in electrostatic equilibrium and there is no electric field? I'm not quite sure on how to think through it.
Isn't that technically the same as a hollow sphere with charges uniformly distributed around it?
Ah, I guess it is. Can you tell me if this explanation is correct?
All the excess charge in the conductor must be located at the surface of the conductor. If we construct a Gaussian surface inside the shell, the net electric flux and the electric field are both zero since there is no net charge inside the conductor.
