Pressure reducing valves (PRVs) do not prevent backflow because they typically lack a tied diaphragm mechanism, which is essential for maintaining a closed system. Most PRVs operate with a check valve arrangement that can allow reverse flow if the inlet pressure drops below the discharge pressure. When this occurs, the pressure on the poppet can overcome the spring force, leading to backflow through the regulator. The need for a thermal expansion tank arises because if both inlet and outlet pressures are high, the valve remains closed, but variations in pressure can lead to unpredictable backflow situations. Understanding the relationship between inlet and discharge pressures is crucial for managing potential backflow risks.
