Why specific heat at near critical point equals differentiate twice Gibbs energy?
The discussion focuses on the relationship between specific heat near the critical point and the second derivative of Gibbs free energy with respect to temperature. It highlights that, unlike the typical first derivative approach, the specific heat is derived from differentiating the Gibbs free energy twice. This concept is supported by references to L.E. Reichl's work, which emphasizes the unique behavior of specific heat at critical points. Understanding this relationship is crucial for grasping thermodynamic principles in phase transitions. The inquiry seeks clarification on this advanced thermodynamic concept.
ndung200790
Please teach me this:
Why specific heat near critical point equals differentiate twice Gibbs free energy with respect to temperature, but not differentiate once with respect to temperature as usually doing.
Thank you very much in advance.
Science news on Phys.org
I mean to differentiate twice with respect to temperature.
I have just found in L.E.Reichl that specific heat equals the result of differentiating twice the Gibbs free nergy(with Y,N=constant).
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
