Calculating Amps and VA for Multiple Secondary Windings in a 28W Transformer
To calculate the current and VA for a 28W transformer with multiple secondary windings, the total power must be shared among the outputs based on the voltage used. The relationship between watts, volts, and amps is defined by the formula W = V x A, allowing for the calculation of current from any two known values. For example, drawing 28W from the 33V winding results in approximately 0.85A, while drawing from the 2.7V winding yields about 10.4A. Each secondary winding must be capable of handling the current drawn, and the primary current will be slightly higher than calculated due to inefficiencies. Proper wire gauge must be selected to prevent overheating based on the current requirements of each winding.
Divendra Nath
I have a transformer that has 120/240 on the primary,but the secondary has multi volt ,33v 0v,13.5v 0v,2.7v 0v 2.7v,9v 0v 9v.The power consumption is 28watts only.How you work out 28watts with all secondary windings to find amps so I can calculate for total VA,and wire gauge?.Some one out there is and has that knowledge to show me the right way to do this please.
It depends on what current you are drawing from what output voltage. If you consume all 28 watts out of the 2.7v output, you'll get a very different current than if you consume all 28 watts out of the 33v output.
Thankyou for your kind response.So how it can be achieved .Do I have to share that 28watts with all secondary.So if I use 28watts with one winding it will be loaded and I can't use it with others.How should I do this?.
I have no idea what your load is going to be so have no possible answer for you.
Correct.
A transformer transfers power between windings through a magnetic field. The total power a transformer can handle is determined by the material and the physical size of both the core and of the wire used in the windings. Different core materials can support different strengths of magnetic field for a given size.
The wire sizes used will determine how much current they can carry before they overheat and burn the insulation, or even melt.
WATTS is the product of VOLTS times AMPS. W = V x A. So if you know any two of them you can find the third one.
In your example if you draw 28W from the 33V winding the current thru that winding will be W/V = A, or 28/33 = 0.85A. If you draw 28W from a 2.7V winding the current there would be W/V = A, or 28/2.7 = 10.4A.
In both cases the primary current (in a perfect transformer) will be W/V = A, or 28/240 = 0.12A. Since no one has come up with a perfect transformer yet, the primary current will be a little bit higher; around 10% to 20% higher is common for small transformers.
Yes.
You can put 28 watts into the primary and apportion it to the secondaries as you see fit, provided each secondary is capable of handling 28 watts worth of current by itself.
Just like paying my monthly bills - if i have $28 available and i have four creditors, i can give $7 to each of them or divide it between them according to my whim.
Likes Tom.G
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
