Wire Gauges: Explaining Sizes & Electric Current Capacity
Wire gauges measure the diameter of electrical wires, with smaller gauges indicating larger diameters that can handle higher electric currents safely. For a device requiring 100 watts, the appropriate wire gauge depends on the voltage; for example, at 120 volts, a 14-gauge wire is typically recommended. The current capacity of a wire is influenced by factors such as insulation type and installation conditions, which can affect heat generation and safety. Chassis wiring refers to the wiring used within the framework of a vehicle or equipment, often requiring specific gauge recommendations for optimal performance. Understanding wire gauge is crucial for ensuring electrical safety and efficiency in various applications.
johnbrown11
Hello,
Can anyone explain to me what wire guages are? It just says its a measurement of how large a wire is and how much electric current in can safley handle. Can anyone give more insight? Also, if I want to power something that requires 100watts what size of a gauge should i use and why?
Thanks
Gauge is a measure of wire diameter (smaller gauge is larger diameter). Larger diameter wires have higher current carrying capability so it doesn't heat up too much and pose a fire hazard. Normal U.S. household wiring is 12 gauge I believe.
http://www.powerstream.com/Wire_Size.htm
what does, Maximum amps for chassis wiring and Maximum amps for power transmission? Also what is chassis wiring?
The copper electrical wire gauge is logarithmic in ohms/1000 feet:
0 Ga. 0.1 ohms/1000 ft
10 Ga. 1 ohms/1000 ft
20 Ga. 100 ohms/1000 ft
30 Ga 1000 ohms/1000 ft
The recommended max amps for a specific wire gauge is based on power loss and heating. e.g.,
Bare wire with convection cooling
insulated wire with convection cooling
insulated wire in bundles or in conduit
Chassis wiring
Bob S
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
