How to Determine the Block's Position After Applying Force to a Spring?
In summary, the problem involves finding the position of a block after applying a force of 63 N and doing 4.1 J of work on a spring-block system. Using the equation +4.1 J = (1/2)k * (xf2 - xi2), we can solve for the block's position and get two answers: -0.4 cm and 0.4 cm. After some confusion and calculations, the correct answer is determined to be approximately 0.0557 m or 5.57 cm.
queenspublic
59
1. Problem
In the figure, we must apply a force of magnitude 63 N to hold the block stationary at x = -2.0 cm. From that position we then slowly move the block so that our force does +4.1 J of work on the spring-block system; the block is then again stationary. What is the block's position (x)? (There are two answers.)
Here's the figure: http://www.webassign.net/hrw/7-11a.gif
? cm (smaller value)
? cm (larger value)
2. Attempt at a solution
(+63 N)î = -k(-2.0 cm)î k = 3.15 x 103 N/M
xi= -2.0 cm
I got some weird decimal answer which was apparently wrong.
I also don't understand what the smaller and larger value is.
What did you get?
You could move the block in either direction.
So the smaller value is negative and the larger value is positive, am I right?. I tried -0.4 too. It's wrong.
How did you get the answer of 0.4? (40 cm?) The equation you posted previously looked OK to me. Did you solve it?
Yeah, I got xf = 0.4 cm.
Redo your solution. (And check your answer by plugging back into the original equation and seeing if it works.)
I got 2 this time. Am I suppose to convert that to something?
This is the equation you're solving, right? When you get an answer, plug it back into the equation to verify it.
How are you solving it? Show each step along the way.
I got 2. I'm sure.
Square root of this [4.1 / (1/2)(3.15 x 103) + (-2.0)2]
queenspublic said:
I got 2. I'm sure.
Use standard units: 2.0 cm → 0.02 m.
Ah crap, you're right.
So it's...Square root of this [4.1 / (1/2)(3.15 x 103) + (-2.0 x 10-2)2]
That looks better.
Okay, I get 160.7. Do I have to convert that or something?
Please double-check that answer. (Is 160 m a reasonable answer?)
It's wrong. I got 160.
Let's do it step by step.
A = 4.1 / (1/2)(3.15 x 103) = ?
B = (-2.0 x 10-2)2 = ?
A + B = ?
√(A + B) = ?
A = 25830
B = 4e-4
A + B = 25830.0004
? = 160.7
I tried 161, it's also wrong.
queenspublic said:
A = 25830
Way off. (You're probably multiplying where you should be dividing.)
A = 4.1 / [(1/2)(3.15 x 103)] = ?
o wait a second...you're right
I got .0027. Do I have to convert this?
No conversions needed.
My final answer is .0557, do I have to convert this answer?
I'm getting multiple answers. Second time, I got .0548.
The second one is correct--at least it's the same answer I get. (You're getting multiple answers, most likely, because you are rounding off different parts of your solution.)
Since it's a distance, the answer is in meters. If you want the answer in cm, then you can convert.
1. What is "work done" in relation to a spring force?
"Work done" is a measure of the energy transferred to or from an object as a result of a force acting on it. In the context of a spring force, it refers to the amount of energy required to compress or stretch a spring.
2. How is work done by a spring force calculated?
The work done by a spring force can be calculated using the equation W = 1/2kx^2, where W is the work done, k is the spring constant, and x is the displacement of the spring from its equilibrium position.
3. What is the relationship between work done and the displacement of a spring?
The work done by a spring force is directly proportional to the displacement of the spring from its equilibrium position. This means that the greater the displacement, the more work is done by the spring force.
4. Can the work done by a spring force be negative?
Yes, the work done by a spring force can be negative if the displacement of the spring is in the opposite direction of the force applied. This indicates that the spring is releasing stored energy instead of being compressed or stretched.
5. What are some real-life applications of work done by a spring force?
Work done by a spring force can be seen in many everyday objects, such as trampolines, pogo sticks, and shock absorbers in cars. It is also used in industrial and engineering fields, such as in the design of springs for various machines and equipment.
