Work done on a gas in a cylinder
The discussion revolves around calculating the work done on a gas in a cylinder through various thermodynamic processes. The gas undergoes an expansion where pressure is proportional to volume, followed by isobaric cooling and isochoric cooling. The participants express confusion over the correct equations for work, particularly during the expansion phase, questioning whether it is isothermal or another type. They emphasize the importance of using a PV diagram to visualize the processes and calculate the work done accurately, noting that the net work is derived from the area between the paths on the graph. The conversation highlights the need to apply signs correctly when summing the work from different processes to determine the total work done on the gas.
Funktimus
A cylinder with initial volume V contains a sample of gas at pressure p. The gas is heated in such a way that its pressure is directly proportional to its volume. After the gas reaches the volume 3V and pressure 3p, it is cooled isobarically to its original volume V. The gas is then cooled isochorically until it returns to the original volume and pressure.
Find the work W done on the gas during the entire process.
W = 0 (for the isochoric cooling)
W = -p(V_f - V_i) for the isobaric cooling
W = -nRT * ln (V_f/V_i) <---- this is what I'm unsure about.
Total Work is going to equal the sum of the 3 work on the 3 processes:
the expansion
the cooling
the further cooling
Expansion process (isothermal?)
W_1 = -nRT * ln (V_f/V_i)
pV = nRT
W_1 = -pV * ln (V_f/V_i)
This is wrong but I don't know why. I don't know for sure that this an isothermal process. But it's not isochoric (because V changes from V to 3V). It's not isobaric because pressure increasing from p to 3p. It's not adiabatic because Q > 0, I think; it's being heated after all. So isothermal seems to be the right answer.
For the second process
W_2 = -p(V_f - V_i) = -3p(V - 3V)
That I'm sure is right
For the third process
It's isochoric, so 0 work is being done.
This is the problem, as you suspected. It would help to draw a PV diagram.
dW = PdV where dW is the incremental work done BY the gas.
Since PV=nRT, and since V/P = k (constant), what does the P-V graph look like? How do you calculate the area under that part of the graph? What does the area represent?
Correct.
AM
The problem gave me that equation.
But when you integrate it, it comes out to be:
W = -p_i*V_i * ln(V_f/V_i) = -p_f*V_f * ln(V_f/V_i)
I even have a page in my physics book that derives it for me. But according to masteringphysics, that's wrong.
But if I draw a P-V graph, it doesn't look like that at all, assuming I did it right. V/P is constant, so it has a constant slope, so it'll just be a triangle. Hence I think the equation is...
-(1/2)(pf - pi)(Vf-Vi) = -2pV
Is that right?
Is that right?
Not quite. If V/P = k then PdV = VdV/k . If you integrate that, you get:
W = \frac{1}{2k}(V_f^2 - V_0^2)
Since V = kP this works out to:
W = \frac{1}{2}(P_fV_f - P_0V_0)
The work done by the gas is all of the area under the graph for each path (when it compresses, the work done is negative (ie. done on the gas) so you have to subtract that area, leaving the area in between the paths as the net work in the cycle.
You are quite right that you can see this from the straight line graph. That is why you should always do a PV graph!
AM
Thanks for the solution. But I don't understand why your integral is so much different from my textbooks. I'll have to bring it up in discussion. Thank you though.
You have to determine W2 and W3 and add them to W1 (applying the signs correctly - you actually subtract the area under the second path). This gives you the net area - the area between the path lines. It is the area between the paths that gives you the work done on/by the gas.
If you draw the path on a PV diagram, you get a triangle between the paths. The area of that triangle is negative (since the area under the compression phase, which is negative work by the gas, is greater the area under the expansion phase, which is positive).
AM
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
