How Does the Angle of Force Application Affect Work Done on a Cart?
The discussion revolves around the work done by a shopper pushing a cart in a supermarket at different angles. For part (a), the work done while pushing at a 25.08-degree angle is calculated using the formula W = Fd, resulting in a specific value. In part (b), when the shopper pushes the cart horizontally, the applied force changes, leading to a smaller force needed to maintain the same speed against friction. For part (c), although the distance remains the same, the work done on the cart is not simply the product of force and distance due to the change in angle, clarifying the confusion about the force value. Ultimately, understanding the angle's impact on force application is crucial for accurately calculating work done.
Zynoakib
A shopper in a supermarket pushes a cart with a
force of 35.0 N directed at an angle of 25.08 below
the horizontal. The force is just sufficient to balance
various friction forces, so the cart moves at constant
speed. (a) Find the work done by the shopper
on the cart as she moves down a 50.0-m-long aisle.
(b) The shopper goes down the next aisle, pushing horizontally
and maintaining the same speed as before.
If the friction force doesn’t change, would the shopper’s
applied force be larger, smaller, or the same?
(c) What about the work done on the cart by the
shopper?
I only don't understand (c)
W = Fd
The answer for (c) is "the same" (as the answer of (a) which is 1586N). I understand since the car travels the same distance, the work done by force should be the same as (a), but if I use W = Fd to calculate (c), it should be W = (35)(50) which is not the same as (a). So, why is that?
Thanks!
For (c), the force done on the cart is not equal to 35 anymore. The speed of the cart is maintained, but not the force. Remember that the force is no longer applied at an angle.
Likes Zynoakib and senan
What did you answer for b?
(Your answer to a has the wrong units.)
smaller
Ok, I get it now. Thanks!
