Calculate Speed of Crate on Incline using Work-Energy Principle
  • Thread starter Thread starter kieran89
    Work-energy
The discussion focuses on calculating the speed of a crate on an incline using the work-energy principle. A 10kg crate is pulled up a rough incline with a force of 100N, and the coefficient of kinetic friction is 0.40. The initial speed is 1.5m/s, and after pulling the crate 5m, the calculations reveal that friction must be accounted for as negative work, affecting the final speed. The correct approach involves determining the net force acting on the crate and ensuring that the work done by friction is treated as negative. Ultimately, the final speed of the crate is calculated to be approximately 2.5 m/s.
kieran89
1. A crate of mass 10kg is accelerated up a rough incline with an initial speed of 1.5m/s. The pulling force is 100N parallel to the incline, which makes an angle of 20deg with the horizontal. The coefficient of kinetic friction is 0.40 and the crate is pulled a distance of 5.0m. Use the work-energy princple to calculate the speed of the crate after 5m.
Am I right or wrong?
2. KE1 + PE1 + Ffr*d = KE2 + PE2
Coefficient of Friction = Ffr/Fn
I got 36.83N for the force of friction.
From my working out I know I have the work done by friction but if i put it on the other side I will have a negative number in my final solution.
(therefore my equation below doesn't actually make sense to me, if I am understand correctly? I am saying with that equation that the inital energy includes friction energy!)
3.
=1/2 X 10 X 2.25 + 0 + 36.83 X 5 = 1/2 X 10 X v2 + 10 X 9.8 X 5sin20
=11.25 + 184.15 = 5v2 + 167.59
v2 =(195.4 – 167.59) / 5
v = sqrt(5.562)
= 2.538
v= 2.5 m s-1
First of all find the net force acting on the crate.
100 N up
mg*sin20...down
μ*mg*cos20...down. Find net force.
work down on the crate = Net force *displacement...(1)
Change in KE = 0.5*m*v2^2 - 0.5*m*v1^2...(2)
Equate 1 and 2 and solve for V2.
Your expression has the wrong sign for the "work done by friction". This work is always negative because the displacement and the force are always at 180 degrees with respect to each other which makes the cosine of the angle between them - 1.
Another way to look at it: KE2 + PE2 must be less than KE1 + PE1 because some Joules are lost to friction. If the three terms on the left are all positive, then KE2 + PE2 is a greater number than KE1 + PE1.
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
