Calculating Gasoline Consumption for Car Acceleration
To calculate gasoline consumption for a car accelerating to 29.1 m/s with a mass of 1500 kg and 40% engine efficiency, the kinetic energy (KE) at that speed is 635,107.5 J. The energy content of gasoline is 9.38 × 10^5 J/oz, and after accounting for efficiency, the usable energy per ounce is 375,200 J. Dividing the kinetic energy by the usable energy per ounce results in a consumption of approximately 1.69 ounces of gasoline. The calculations appear to be correct based on the provided information. This method effectively demonstrates how to determine fuel consumption during acceleration.
Crush1986
Gasoline has an energy content of 9.38 × 10^5 J/oz. If a car,
with a mass of 1500 kg, is accelerated to a speed of 29.1
m/s, how much gas is consumed by the engine, assuming
40% efficiency?
w=fd
w= ΔKE
So I started by multiplying the energy content of gasoline by .4 so I believe I could just treat it was being 100 percent efficient after that.
I then calculated the KE the car had at the end of it's acceleration. 1/2*(1500kg)*(29.1 m/s)^2 = 635107.5 J. I then divided this by the amount of energy a car uses per oz of gasoline which was .4 * 9.38*10^5 J/oz to get the oz's. Which was 1.69.
Is this all correct?
Thank you to anyone for their time.
