Work required to move a charged ball
  • Thread starter Thread starter Black Armadillo
    Ball Charged Work
Black Armadillo
A ring of diameter 7.10 cm is fixed in place and carries a charge of 5.00 μC uniformly spread over its circumference. How much work does it take to move a tiny 3.40 μC charged ball of mass 1.70 g from very far away to the center of the ring?
I tried using: W=-\Delta U
We know that when the ball is very far away U=0J
Then to find the potential energy when the ball is in the center of the ring I did:
Change in charge is 5.00X10^{-9}C/2\pi(0.0710m)=1.12X10^{-8}C/m
\int \frac{k*q*dq}{r} ds from 0 to 2pi.
\frac{k*q*dq}{r} \int ds from 0 to 2pi.
\frac{8.988X10^{9}N*m^2/C^2*3.40X10^{-9}C*1.12*10^{-8}C/m}{0.0710m} \int ds from 0 to 2pi =3.031X10^-5J.
W=-\Delta U=-(3.031X10^-5J-0J)=-3.031X10^-5J
I'm having trouble following your integral from the first line. I'm thinking V = kq/r for a point charge so dV = k/r*dq, where r is the radius of the ring.
Ah, you are doing energy E = QV so dE = QdV = kQ/r*dq
I'm using q for the charge on the ring, Q for the charge on the particle.
Your s must be something to do with the arc length going round the ring.
So dq = q/(2*pi*r)*ds
Using s = r*A where A is the angle running from 0 to 2pi, you get ds = r*dA and
dq = q/(2*pi)dA
so the integral is dE = kQq/(2*pi*r)*dA from A = 0 to 2*pi.
The nice thing about this integral is that nothing depends on the angle so
integral 0 to 2*pi of dA is just 2*pi.
E = kQq/r.
Well, I guess we didn't need to integrate at all! Because all the charge is the same distance from the center point.
I'm still slightly confused. So I can find E at the center of the ring using E=kQq/r. But, since W=-(U_f-U_i) how do I get U from E? Since E=kq/r^2 and U=kq_1*q_2/r would you just multiply the E you get by qr and if so what q would you use: the charge on the ring or the charge on the ball? Thanks for your help.
Try this approach. Find E as a function of r along the axis of the ring using integration. Then
V=-\int_{\infty}^{r}\mbox{Edr}
The work done is
W=Vq
Is the mass in a gravitational field also and if so what is the orientation of the ring axis with the field?
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
