Work, Vertical and Horizontally
  • Thread starter Thread starter Bigdane
    Vertical Work
The discussion focuses on calculating the work done by a person lifting a 3.7 kg cement block vertically and then carrying it horizontally. The work done in lifting the block can be calculated using the formula w = fd, where f is the force (weight of the block) and d is the distance lifted. In contrast, the work done while carrying the block horizontally is zero, as there is no vertical displacement. Gravity does negative work during the lifting process, equal to the weight of the block multiplied by the distance lifted. Understanding these principles is essential for solving similar physics problems.
Bigdane
A person lifts a 3.7 kg cement block a vertical distance of 1.18 m and then carries the block horizontally a distance of 7.80 m.
(a) How much work is done by the person in the process?
J
(b) How much work is done by gravity in the process?
J
w=fd?
J
J
w=fd?
OK. How much work then in lifting?
How much in carrying?
im not sure how to find that
got it. thanks
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
