Can x be expressed in terms of a?
  • Thread starter Thread starter wisredz
    Terms
The discussion revolves around expressing x in terms of a through a series of equations: x^2 = y + a, y^2 = z + a, and z^2 = x + a. The original poster has derived an eighth-degree polynomial but struggles to simplify it effectively. Another participant suggests using the quadratic formula to express x in terms of z and a, noting that while two roots are straightforward, the remaining six are part of a complex sixth-degree polynomial. The conversation highlights the challenge of finding a clear solution and the potential use of numerical methods like Newton's method for approximation. Overall, the problem remains unresolved, with participants seeking clearer mathematical expressions.
wisredz
Hi,
I have a problem with the following problem. We have to write x in terms of a.
x^2=y+a
y^2=z+a
z^2=x+a
I have done some work but all I got is eighth degree polinomial and there is no easy wayof solving it in terms of a as far as I know. This is what I have
((x^2-a^2)^2-a)^2=x
Any help is appreciated
Cheers,
Can
wisredz said:
Hi,
x^2=y+a
y^2=z+a
z^2=x+a
((x^2-a^2)^2-a)^2=x
Cheers,
Can
That does not look quite right
x^2 - a = y
y^2 - a = z
z^2 - a = x
\left( \left[ x^2 - a \right ]^2 - a \right )^2 - a = x \ \ \ \ ?
Ummm, yes that's what I have but it seems I have written it wrong. I should have 8 roots x in terms of a in this case but I can only think of Newton's method to find those. That is not a very good idea actually...
Nice question,
Think about using quadratic formula with x in terms of z and a.
2 of the roots are simple quadratic roots but the other 6 can not be simplified any further than they are roots of an akward 6th degree polynomial.
Do you mean something like this? English is not my native tongue so I have a little difficulty with mathematical terms. this is what I have now
x^2+x-\sqrt (z+a) -z^2=0
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
