XP Laptop cannot access network
  • Thread starter Thread starter Ralf66
    Laptop Network
7 replies · 2K views
Ralf66
My ancient Dell laptop used to work fine, but now I cannot access ethernet network we're on. It claims the speed is 1 Gbyte or 1 GHz too. I checked the connection by bringing in my MacBk Pro but that is not a viable option for this location. We have no "UT person" - it is roll your own.
Any ideas??
Problem could be hard or soft, you might as well try using a different ethernet cable, it's somewhere to start.
I used the same cable and it worked on another laptop, as per the OP.
any ideas on what I can do to the Dell laptop?
See if somebody can lend you access to a different ethernet connection/router to eliminate all possibility of configuration problem at that end.
Could be that the physical ethernet plug in the laptop is dirty/weak/damaged.
Windows has a basic network connection analysis tool, which can be found in the control panel.
It will tell you whether the OS is recognising a physical network connection is present.
If that shows a network connection as as being present but it doesn't seem to do anything, you are probably looking more at a software issue.
Check to make sure your device is enabled in both windows and your bios. If it is, try reinstalling the drivers (should be able to get them off of dells website: support.dell.com), and simply plug in your service tag on the sticker under your laptop (or just enter the model if you no longer have that sticker).
1Ghz would be how fast your processor (or cores if a multicore processor) which doesn't affect your NIC (at least directly).
Is your Ethernet card a PCMCIA card (inserted into the laptop in those thin wide slots) or is it built into the mainboard?
Take it home and try it. Does it work there? If not, it is probably hardware or drivers.
If it works at home, do as Svein said, start with ipconfig -all and compare it to a working machine on that network.
Does the network port light light up or blink? Is it that same as a working machine?
Can it access anything on the network? Have you tried an IP address. If DNS is configured wrong it would look like the network was not working.
Maybe it is configured with a fixed IP address and the network wants DCHP.
reconfigure your ethernet properties from control panel.
go to control panel ---> network and internet connection ---> network connection
now choose your ethernet and configure ethernet properties with the username and password which your isp has provided.
