How Many Constructive Interference Fringes Are Formed on the Screen?
The discussion focuses on calculating the number of constructive interference fringes formed by 605-nm light passing through slits separated by 0.120 mm. The initial calculation suggests there are 397 fringes, including the central maximum. However, this is incorrect as it improperly assumes sin(theta) equals one. The correct approach requires a reevaluation of theta to accurately determine the maximum number of fringes, which is stated to be 265 according to the textbook. Understanding the geometry of the interference pattern is crucial for accurate calculations.
Wheelwalker
605-nm light passes through a pair of slits and creates an interference pattern on a screen 2.0 m behind the slits. The slits are separated by 0.120 mm and each slit is 0.040 mm wide. How many constructive interference fringes are formed on the screen? (Many of these fringes will be of very low intensity.)
d*sin(theta)=m*lambda
By solving the above equation for m and setting sin(theta) equal to one, I can find the number of fringes on one side of the central maximum, then multiply that number by two and add one (for the central maximum).
So, m=(d*sin(theta))/lambda=((0.120*10^-3)*(1))/605*10^9=198.35
This means there are 198 fringes on each side of the central maximum, correct? So, 198*2=396. And then, accounting for the central maximum, 396+1=397.
This answer is wrong. The correct answer in the back of the book is 265 fringes.
Have a look at theta again. You can't just set sin theta to 1.. Have a look at a diagram of the experiment to see what theta actually corresponds to
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
10K
