Solve "Zero Electric Charge" Homework: x = 51.641 or -3.643
The problem involves determining the point along the line joining two electric charges, Q1 and Q2, where the electric field is zero. The charges are Q1 = 0.0306 μC and Q2 = -0.0206 μC, separated by a distance of 4.17 cm. The original poster attempts to find the distance x from Q2 where the electric field cancels out.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss setting the electric fields from both charges equal to each other to find the point of zero electric field. There is confusion regarding the correct setup of the equations, particularly whether to use squared distances and how to account for the signs of the charges.
Some participants suggest that the null point cannot be between the two charges due to their differing signs. There is ongoing exploration of the algebra involved in solving the quadratic equation, with multiple interpretations of the setup being discussed. Guidance has been offered regarding the use of charge ratios and the importance of correctly identifying coefficients in the quadratic equation.
Participants express uncertainty about the units and whether the results should be in meters or centimeters. There is also mention of potential errors in algebraic manipulation and coefficient identification in the quadratic formula.
GDGirl
A charge Q1 = 0.0306 μC is located a distance d = 4.17 cm to the left of another charge Q2 = - 0.0206 μC.
a. At what point along the line joining the charges is the electric field zero? Give your answer as the distance x from the charge Q2, positive if the point lies to the right of Q2 and negative if to the left.
HELP: First figure out the approximate region in which the third charge can be placed so that the electric forces from the first two charges will balance.
HELP: Set the electric fields from Q1 and Q2 equal at position x--you will have to solve a quadratic equation to find x.
E=kQ/r2
Quadratic equation
First I solved the for the electric field of both charges, but I'm not sure if that is relevant to my problem or not.
Then, I followed the Help's advice, and set my two equations equal to each other:
-((8.99x109)(.0206x10-6))/(.0417-x)2=((8.99x109)(.0306x10-6))/x2
I ended up with x = 51.641 or -3.643. Neither is correct as confirmed both by my plugging in the numbers and checking, and submitting the answers in my answer box. :/
I'm confused about whether x should be squared or not, I'm pretty sure it should be. If the E-field of my negative charge should be negative or not... And if i should be doing .0417-x as the distance in said E-field...
E=kQ/r2
Quadratic equation
Unfortunately you didn't follow the first hint. Since the field between the charges is not 0 anywhere in between, since 1 is positive and the other is negative, then constructing your equation as x and .0417 - x won't work.
If there is a null point anywhere, then it must be to the other side of wherever the other charge. Hence if the distance to Q2 is x, then the distance to Q1 would be .0417 + x.
If there is a null point anywhere then it must be to the other side of wherever the other charge. Hence the distance to the Q2 is x and the distance to Q1 would be .0417 + x.
alright, I just tried that out, too, and it didn't work either. I'm still getting it wrong, and I'm not quite sure where things are going wrong. I'm fairly positive it must be with my algebra, because things just aren't working out algebraically. :/
You should end with the simple equation that
Q1/(.0417 + X)2 = Q2/X2
Okay, I just tried that, and I'm still getting it wrong. It's closer than it was before, because the point isn't meters away from the charges.
I ended up with x being equal to either 5.246x10-7 or -5.318x10-6.
LowlyPion said:
I don't get that at all.
306/(.0417 + X)2 = 206/X2
(306/206)*X2 = .001739 +.0834X + X2
0 = .001739 +.0834X - .485X2
Here's a quadratic calculator:
http://www.math.com/students/calculators/source/quadratic.htm
Except that the charges aren't 306 and 206. They'd be .0306x10^-6... :/
Yeah ... but.
The ratio is all you care about.
LowlyPion said:
Yeah ... but.
... You've lost me.
GDGirl said:
... You've lost me.
(Q1/Q2)*x2 = (.0417 + X)2
Regardless of what the charges are, you are only concerned with their ratio. The rest of it just cancels out.
I don't think I understand why I'm only concerned with the ratio. If I need to find a specific point that would only happen with these two charges, wouldn't I need to use the exact charges?
EDIT: Either way, I tried out the numbers you came up with above in the quadratic equation, and those are the exact same numbers I came up with originally when I tried this. Unfortunately, I'm fairly positive the distance is not 500 and some odd cm.
OK.
Which result is different?
306/206 =
or
.0306*10-6/.0206*10-6 =
No you did not try these coefficients in the quadratic equation.
You get no where near 500cm.
I copy and paste the coefficients into the quadratic calculator.
X1=5.242314636470677
X2= -53.20091153123778
The answer should be in meters, therefore it is 500 some cm.
Unless for some reason it isn't in meters, which I don't really think is the case, since the original equation calls for meters.
I do see what you mean about the ratios, though. Those are exactly the same.
LowlyPion said:
Apparently you have swapped A and C, because that gives you the numbers you are finding.
So go to this link:
Input these three coefficients:
A = - .485
B= .0834
C = .001739
This will sort things out for you.
You're completely right. I need to make a note of what is a and c for the quadratic equation
Fantastic- thank you! :)
