A very long uniform line of charge has a charge per unit length of 4.82 uC/m
The discussion revolves around calculating the net electric field at specific points along the y-axis due to two parallel lines of charge. The first line has a charge density of 4.82 µC/m, while the second has a charge density of -2.46 µC/m. Participants express confusion about how to apply the electric field equations correctly, particularly regarding the integration and the distances involved. Suggestions include reviewing relevant physics resources for guidance on electric fields from continuous charge distributions. The conversation emphasizes the need for clarity in applying formulas to find both the magnitude and direction of the electric field at the specified points.
xxaznitex
A very long uniform line of charge has charge per unit length 4.82 uC/m and lies along the x-axis. A second long uniform line of charge has charge per unit length -2.46 uC/m and is parallel to the x-axis at y1= 0.418
1-)What is the magnitude of the net electric field at point y2= 0.202 m on the y-axis?
2-)What is the direction of the net electric field at point y2= 0.202 m on the y-axis?
-y-axis
+y-axis
3-)What is the magnitude of the net electric field at point y3= 0.608 m on the y-axis?
4-)What is the direction of the net electric field at point y3 = 0.608 m on the y-axis?
-y-axis
+y-axis
EA=PA/epsilon-nought
E=kq/r2
I don't really know where to start.
At first I tried to do E=(k*dq)/r^2 = k(4.82e-6)/(x^2+.202^2)
But then realized that I don't have a definite integral. Then I tried to use E=(kq1/r1)+(kq2/r2)... but the answer was incorrect. Anyone know how to start this problem..?
