Pendulum with its pivot accelerating upward
The discussion centers on deriving the equation of motion for a pendulum attached to a massless support that accelerates upward. The Lagrangian approach yields the equation bθ'' + (g + a)θ = 0, but there is uncertainty about using Newton's formulation. To apply Newton's laws, one must express the pendulum bob's position in relation to the support's position, the pendulum length, and the angle. The acceleration of the bob can then be determined, incorporating the upward acceleration of the support. Visualizing the forces through a free body diagram and combining the effects of gravity and support acceleration simplifies the analysis.
AlonsoMcLaren
A pendulum of length, b, and bob with mass, m, is attached to a massless support moving vertically upward with constant acceleration a. Find the equation of motion.
This problem is easy with the help of Lagrangian dynamics: bθ''+(g+a)θ=0
But how to solve this problem using Newton's formulation? I really have no idea... Apparently only the tension of the string and gravity are acting on the bob. But the tension of string seems very complicated...
Start by writing the position of the pendulum bob in terms of the support position, ys, the pendulum length, and the angle of the pendulum. Then differentiate to find the acceleration of the bob. From there on it is fairly straight forward F = ma, with a support motion term included.
Just combine a+g and treat that sum as the effective amount of gravity for the pendulum.
Draw the FBD, show the vectors, and then it will make more sense. Just talking about it does not help very much. You need to actually work with the math to see what is going on.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
15K
13K
