Finding a max load from the yield stress
To determine the maximum load a bar can withstand, the yield stress and dimensions of the bar must be considered. The bar is 500mm long, 10mm wide, and 3mm deep, with a maximum yield stress of 150 MPa. The bending moment was calculated to be 3.75 at 250mm, leading to an equation involving stress and moment. However, the calculated load of 9N does not align with the applied load of 30N, indicating a potential miscalculation. Clarification on the bar's support, which is simply at both ends, is crucial for accurate calculations.
Lap9387
1. Homework Statement I have a bar, 500mm long (0.05m) 10mm wide (0.01m) and 3mm deep (0.003 m)The bat has a load applied in the centre of 30nI know the maximum yield stress is 150 mpa 150x10^6How do I calculate the maximum load the bar can take?2. Homework Equations I used stress = m y / I3. The Attempt at a Solution I calculated the bending moment to be 3.75 at 250mm (.25m) using a shear bending diagram,*I then reversed the equation above to get:150x10^6 = 0.0015m/2.25x10^-11Which gives m as : (150x10^6 x 2.25x10^-11) / 0.0015M = 2.25I know the bending moment is at .25 mSo divide 2.25 / .25I get 9The answer can't be 9n as the question uses 30nCan someone please show me how to solve this?.Thanks in advance x*
You missed the most important point. How is the bar supported?
Sorry, the bar is simply supported at either end
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
