How Does Newton's Cradle Demonstrate Conservation Laws in Physics?
  • Thread starter Thread starter tnutty
    Exam Study
The discussion focuses on the physics principles illustrated by Newton's Cradle, specifically conservation of momentum and energy during elastic collisions. Participants explore calculations related to the velocities of the balls before and after collisions, emphasizing the relationships between mass, height, and speed. There is confusion regarding the correct formulation of the conservation laws, particularly in expressing momentum and energy equations for different mass scenarios. Additionally, participants seek clarification on how to derive specific speeds and heights post-collision, indicating a need for further assistance in solving these physics problems. The conversation highlights the importance of accurately applying conservation laws in analyzing Newton's Cradle dynamics.
tnutty
Imagine a regular Newtons cradle (google it). The problem gives a the following information.
All the spherical ball have the same mass. Ball 1, m_1 is initially raised at height H_i.
A) Consider a stack consisting of just two balls. Let the speed of the first ball just before the collision be V_o. Solve V_f in terms of H. Solve for V_0 in terms of H.
ANS : Using the conservation of energy equation I got H = 0.5V_f^2 / g.
B) Just after the collision , the first ball bounces back at speed V_1, and the second ball moves forward at speed V_2. State the law of conservation of momentum for the general cases of masses m_1 and m_2 in terms of speed V_1 , V_2, and V_f ?
not sure what this is asking. Is is just m_1*V_1 + m_2*V_2 = m_1*V_1f + m_1 * V_1f
C) State the law of conservation of energy for elastic collision for the general case of masses m_1 and m_2 in terms of speed V_1, V_2, and V_f?
Is it just 1/2(m_1*V_1 + m_2*V_2) = (m_1*V_1f + m_1 * V_1f) 1/2
D) Solve for the speeds V_1 and V_2 for the special case that m = m, and m_2 = 2 M using the equations from part b and c above. Show that your solution satisfies the conservation of momentum and energy during the collision.
NEED HELP ON THIS PART!
E) To What height,H_1 will the first mass rebound after the elastic collision? To what maximum height, H_2, will the second mass rise before falling back.
Intuitively , H_1 rebounds to height 0.
And not sure about the next part.
Hi tnutty! :smile:
That's correct … except shouldn't you have put one of them = 0? :wink:
hmmm … what's in your brain may be correct, but what you've written is the same as for momentum :redface:
Find either V1 or V2 from the first equation, and substitute that value into the second equation :smile:
Part C is 1/mv^2 for each with initial and final.
pard D) How do you find v_!1?
And how would you find at what H_1, and H_2 the ball reaches, if the mass
ratio of m1/m2 = 1/3, or 4/2 ?
Do you mean 1/2 mv2 ?
As I said before: Find either V1 or V2 from the first equation, and substitute that value into the second equation :smile:
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
