Mech King
- 69
- 0
Hello everyone,
I have a beam deflection problem. I haven’t looked at deflections for a while now and I can't understand why my solution is a million miles out fro the results I have seen through testing.
Problem:
I have a beam made from 100x40x3mm mild steel box section which is 2100mm in length. See attached figure for free body diagram of the loading on the beam. Please note the loads P1, P2 and P3 are applied individually and then removed before applying another load, so there is only one load on the beam at anyone time.
The beam is welded to the supports underneath the beam (labeled “support reactions”)
The beam is loaded against its widest face and hence I have used the “second moment of area” value as given from the data sheet in its Y axis.
Relevant formulas:
E=200,000 N/mm2 for steel
I = 361000 mm^4
Solution:
My first load case is the individual force P1 applied to the left hand side of the beam:
P1=22,017N
Cantilever moment load (as per Shigley’s Mech eng Design book):
Ymax = (M*L^2)/2EI
Ymax = [(22017*177.5^2)*177.5^2]/(2*E*I)
Ymax = 0.86 mm
Query of Solution:
I have had this problem tested and the deflection of the beam was 6.77mm. My results are showing a figure which is about 8 times too small?
Could somebody please help me understand where I am going wrong?
I have a similar problem with the remaining two load case scenarios set out in the free body diagram, for loads P2 and P3 also, but I wanted to clear up this scenario here before progressing.
What do you think?
Problem:
Relevant formulas:
I = 361000 mm^4
Solution:
P1=22,017N
Ymax = (M*L^2)/2EI
Ymax = 0.86 mm
Query of Solution:
What do you think?
