miamirulz29
- 62
- 0
Water flows through a .259m radius pipe at the rate of .125m^3/s. The pressure in the pipe is atmospheric. The pipe slants downhill and feeds into a second pipe with a radius of .190m, positioned .796m lower. What is the gauge pressure in the lower pipe? The acceleration of gravity is 9.81 m/s^2. Answer in the units of Pa.
A1V1 = A2V2
flow speed = flow rate / area
P1 + [(Rho)(g)(h1)] + [(1/2)(rho)(V1^2)] = P2 + [(Rho)(g)(h2)] + [(1/2)(rho)(V2^2)]
Calculating the flow speed gives me V1. Then I can find V2 using the equation of continuity.
Also, because we are looking for gauge pressure, I am look for P1- P2. Therefore:
P1-P2 = [(rho)(g)(delta H)] + [(1/2)(rho)(V2^2)] - [(1/2)(rho)(V1^2)]
Is this correct? Also, do I need to do anything for P1 if that pressure is atmospheric in the pipe? Thanks in advance.
