To determine the angle theta for numerical integration of lift and drag using pressure distribution, divide the airfoil into panels and calculate the angle of each panel with the horizontal using arctan((y2-y1)/(x2-x1)), then add 90 degrees for the angle to the normal. Care should be taken with the sign of the calculated angle. For calculating the moment coefficient around the quarter chord point, the lift from the trapezoidal rule should be multiplied by the distance from the quarter chord to the panel in question. The method of using only the distance from the quarter chord to the panel for moment calculations is correct, but ensure clarity on how lift is integrated across panels. Proper understanding of these calculations is essential for accurate aerodynamic analysis.
