Japan Earthquake: Nuclear Plants at Fukushima Daiichi
The Fukushima Daiichi nuclear plant is facing significant challenges following the earthquake, with reports indicating that reactor pressure has reached dangerous levels, potentially 2.1 times capacity. TEPCO has lost control of pressure at a second unit, raising concerns about safety and management accountability. The reactor is currently off but continues to produce decay heat, necessitating cooling to prevent a meltdown. There are conflicting reports about an explosion, with indications that it may have originated from a buildup of hydrogen around the containment vessel. The situation remains serious, and TEPCO plans to flood the containment vessel with seawater as a cooling measure.
  • #1,051
tsunami wave receding from plant:
video:
  • #1,052
Joe Neubarth said:
They failed about thirty minutes after the Earthquake (and reactor Scram) because they no longer were there.
Could be I misread the information Astro posted here:
https://www.physicsforums.com/showpost.php?p=3185466&postcount=46
My impression was that the tsunami wave was first and they stopped some time later, but now I see it can be read differently - they started immediately and stopped when the wave came.
  • #1,053
Reno Deano said:
The fact that they can get into the plants and grounds around them indicate that there are no spent fuel rods from the SFPs laying about.
Most of us are still trying to find out what is happening and what actually happened.
I am convinced that we had some fuel meltdown. I also know that the steam release to decrease pressure on the reactor carried considerable radiation release with it. That cesium and strontium and iodine came from at least one of the reactors.
Some on here seem to think that Reactor Number Three had a full melt down and loss of fuel material through the reactor vessel.
I keep on looking and can not find a reference to the pressure of Reactor Number three at the present time. Those of you in the know, can you post the present values if they have been released by Tokyo Electric?
  • #1,054
Could it be ... that :
http://www.nisa.meti.go.jp/english/files/en20110325-1-4.pdf
Supression chamber : 2 atm
Dry water : atmospheric
Temperature : relatively low
Radioactivity similar to other reactors
  • #1,055
That is likely the case, Borek. Power turbines are large, but delicate and they trip on anomalous vibration, and likely the plant was set to scram its reactors on input from seismic sensors. Earthquake takes out the turbines and reactors, and the tsunami arrives later and takes out the emergency backup generators. Battery back-ups are limited and can't take the place of backup generators - maybe they have the capability of providing critical instrumentation and closing or opening critical valves to fail-safe conditions.
  • #1,056
If Cesium and Sr got out, where are the other long lived fission products? If am not wrong, there were no significant quantities of long lived fisson products reported to have beern blown by the steam into the environment around and offsite of the plant. Sure there is reactor core and SFP bundles damaged, but some what contained within their respective locales.
  • #1,057
No expert but as I understand it (from here or elsewhere) the battery power controls valves, the back-up system pumps themselves being powered by steam from the reactors. Which is pretty clever for as long as the valves can be controlled.
The amount of battery power available must be a possible lesson-learned thing. 8 hours wouldn't be acceptable for a mobile phone. That's probably very unfair. But also true.
First post here as well, I've been watching this unfold through here. Thanks to everybody, by far the best resource I've found on the web.
  • #1,058
Hi everybody
do you know the chemical properties of compounds and cesium and iodine ? iodine is very volatile, what about Cs and Sr compounds ? could it explain the fact that they could have been emitted together with water vapor , but not heavier elements ?
(1st post too - hello especially to other French people here - very interesting forum)
  • #1,059
About the generators, i think this info will have to be clarified by further inquiry but what i heard about was that they started (probably just after the quake) then stopped after. Looking at the vidéo above of the flooding of the plant we can understand that they have been flooded and probably destroyed as they were on the ground floor of the building, just close to the white fuel tanks as shown earlier on FRED's drawing.
We can be surprised that no mobile power generator could be available soon (I'm talking about these kind of things, like gas turbine generators: http://www.netimago.com/image_181981.html )
I heard an info at the beginning of the crisis that Tepco asked for ten of them... but found on the GE site that only three of them where available... in Florida! Ok i understand that total loss of power (including safety groups) was not a scenario conceived by Tepco and this perfectly demonstrates it...
An other subjet: can somebody give me a good explanation of why Tepco had to vent the H2 inside the buildings (in the top floor) instead of outside? This looks an odd way of doing it, considering that there was a risk of explosion. Why inside instead of outside? This looks strange to me and i find no analysis or answer on this point.
  • #1,060
So why are the pressure readings negative? Those are negative signs I see in front, right?
  • #1,061
concerning the release of volatile cesium, I found that
http://blogs.nature.com/news/thegreatbeyond/2011/03/first_estimates_of_radioactive.html
The researchers estimate that 3x10^15 becquerels of Cs-137 (which has a half-life of 30 years) were released during the first two days following the disaster on 11 March. A further 3x10^16 was released over the next two days, totalling 50% of the Cs-137 emitted in the Chernobyl accident. 4x10^17 becquerels of I-131, with a half-life of 8 days, were likely released over the same period, roughly 20% of I-131 released from Chernobyl. Wotawa says he was "surprised at the cesium levels, but less so with respect to iodine, as its highly volatile."
with this comment
It would be nice if someone would give a better discussion of this result. By my understanding of the definition of a Bequerel, 3x10^16 Bq would amount to about 10 kilograms (!) of Cesium. That size of release seems completely impossible without a major containment failure, which pretty clearly has not occurred.
Posted by: Dean Townsley | March 24, 2011 03:32 AM
are 10 kg plausible ? :confused:
  • #1,062
Don't know why ...
The figures for the inside (I suppose) reactor are hardly understandable.
Below atmospheric pressure un all cases except reactor 1 (and negative for 2 3).
That's why I only read ther Dry well and Supression Chamber.
If anyone has a explanation (except instrumentation broken) ...
  • #1,063
My understanding is limited with respect to what they do, but I read somewhere that they vent steam from the primary inside of the building rather than to the open air. This supposedly is done to decrease the radiation released outside the building.
It looks to me that they did not know that they would be releasing hydrogen from the reactor plant. Hydrogen can come from breaking the bonds of the water molecule, and that could most likely happen in a scrammed reactor if the surface temperature of the fuel plates reached approximately 1000 degrees Fahrenheit. At some temperature in that range, the Zirconium cladding will oxidize with the Oxygen in the water molecule I thing the above is correct but will not be offended if corrected. I am not certain about the temperature needed for the Zirconium oxidation.
  • #1,064
If I recall correctly venting inside of the building means lower chances of radioactive contaminants getting outside, hence the design.
Edit: beaten by Joe.
  • #1,065
Joe NEUBARTH: i asked several times here if we were talking about relative pressures or absolute pressures and got no answer. On the METI doc that you link, i think you'll find an answer if you go down a little bit, to the line "D/W design service pressure". You will read a first pressure number and then the second is defined as "abs" -absolute. So all the numbers you have in this report otherwise specified are relative pressure i think, which explain why it can be negative.
But, it means that on reactors 2 and 3, those pressures are below atmospheric pressure, which is kind of strange and... scary?
Again, it's very difficult to draw a conclusion based on some numbers but to me this could (i say could) mean that the 2 and 3 reactors are dead from their confinement standpoint... and that N°1 is still rising...
All three reactors had explosions, n°1 seemed to bit quite "clean" (outer walls). N°2 had an explosion that nobody saw, it has been said that it was in the suppression pool and that it was leaking. N°3 had 3 simultaneous big explosions (the most impressive) and some here expressed concerns about it's current state.
Concerning the explanation given of why venting in the building instead of outside: ok that's what i heard BUT would you do it deliberately a second time (N°3) after having experienced the first time an explosion in the building (where the pools are!) because of H2 presence? Notice that venting in a room that explodes ends up with everything in the atmosphere + a severe explosion... That's a strange thing.
  • #1,066
Venting to inside the Reactor Building is not the design. The offgas holdup system is the design, but would not be available due to loss of power and valves failing closed. They were in no win situation and vented to the upper part of the building (do not know if they could even control the discharge location), but failed to open the pressure equalization louveres (if they even could). Most new plants have 72 hours electrical backup and hydrogen igniters inside the primary containment to control hydrogen buildup. But then again with a long term station blackout, those may have not worked.
  • #1,067
Thanks Reno, so your explanation is that it's because there was no power available...
So the only vent they could open was inside the building, there was none actionnable toward the outside (what a pity...). Then that was a constraint, not a choice (like to avoid radioactive venting outside), right?
Are we talking about a valve that a man had to actionnate physically being close to it?
The reason why I'm asking these questions is that it seems that a modification has taken place in the US after the TMI accident under the NRC requirement, with the installation on all BWR reactors in the US of a so called "hardened vent" which is a direct realease to the atmophere to depressurize the containement. THis was to avoid precisely H2 release inside the building. Then the question is: did the japanese had this hardened vent? I have the impression that these vents are the big structures (like antennas) that we see close to every reactor (right or wrong?) but in this case it means that they still couldn't activate them because no power (seems not to "hardened" to me but...).
  • #1,068
The IAEA have just measured very high beta/gamma contamination 4,900,000 beq / metre squared in Fuk. Pref.
"At distances between 30 and 32 kilometers from the Fukushima Nuclear Power Plant, in a north westerly direction from the site, dose rates between 16 and 59 microsievert per hour were measured. At these locations, the results of beta-gamma contamination measurements ranged from 3.8 to 4.9 Megabecquerel per square metre. At a location of 21 km from the Fukushima site, where a dose rate of 115 microsieverts per hour was measured, the beta-gamma contamination level could not be determined."
http://www.iaea.org/newscenter/news/tsunamiupdate01.html
Here is a map of Chernobyl's "Zone of Alienation"
I converted 40 curies / square km to 1.48 Megabeq / square metre
Also 1.48 is mentioned here:
http://books.google.com/books?id=g3...age&q=chernobyl cs soil contamination&f=false
We seem to have 4.9 Megabecquerels in Japan
edit: Forgot to mention not all of the radiation detected yesterday by the IAEA was from Cs137, there will be Iodine,Strontium,Cobalt etc and maybe Plutonium too. Also one site was "unmeasureable", but mSv was highest at that point !
  • #1,069
There was also speculation earlier that operators were reluctant to vent until absolutely necessary. That, combined w/ the technical info that the drywell cap could leak H2 under a pressure as low as 2 ATM and w/ the additional technical info that the fuel transfer gate seal (between the upper drywall containment & SFP) is an electric pump-sustained pneumatic seal could explain one possible mechanism for H2 accumulation in the drywell cap region, SFP, and upper building structures that may not have been apparent to operators reluctant to vent earlier, and at lower pressure. Search the earlier portions of this thread for more discussion of same.
  • #1,070
An other extract of the report of AIEA cited above (about hi beta gamma radiation in an area north west of Fukushima):
"Reactor pressure is increasing in Unit 1, pressure readings are unreliable in Unit 2, and stable in Unit 3 as water continues to be injected through their feed-water pipes. The temperature at the feed-water nozzle of the Reactor Pressure Vessel (RPV) is decreasing at Units 1 (243 °C) and 3 (about 185 °C), and stable at Unit 2 (about 102 °C).
Units 5 and 6 are still under cold shutdown, they are undergoing maintenance using off-site AC power and existing plant equipment.
Dose rates in the containment vessels and suppression chambers of Units 1 and 2 have decreased slightly."
So for them, the pressure readings -below 1 atmosphere- in reactor 2 and 3 that we talked about earlier would be unreliable... hummm, maybe.
  • #1,071
Hard facts are hard to come by I'm afraid.
  • #1,072
Yep, I'm not certain I understand what I think I used to know, but I do know that I don't understand what is happening now.
  • #1,073
AND you can quote me on that, too.
  • #1,074
NHK WORLD:
"Caesium 141 found in plant."
Half life 24 seconds ? Please explain
  • #1,075
KYODO: as of 10 minutes ago.
"NEWS ADVISORY: Reactor vessel of Fukushima plant No. 3 unit may have been damaged: Gov't panel"
"NEWS ADVISORY: U.S. forces to provide water to cool Fukushima plant: Defense chief Kitazawa"
Where are all the resident experts?
I need answers to my last 3 posts, the situation is very concerning and still as clear as mud.
  • #1,076
> According to experts, salt from seawater pumped via fire hoses into reactor cores and spent fuel rod pools is depositing on fuel rods and nonoperational cooling systems, diminishing cooling, and that freshwater flushing and usage is critical.
> According to experts, delays (possibly weeks or months) expected due to observed cooling system damage and hazardous work environment.
> Surprisingly both US Marines and Army have Hose Reel Systems (HRS) at Okinawa bases, and should offer HRS to Japanese authorities (may prove invaluable).
> Each HRS has at least 5 miles of 6 inch diameter high capacity lay flat hose (Figure 1), which, along with accompanying mobile pumps, are presently at Okinawa bases.
> Multiple lakes within ~1.2 to 3 miles and beyond from nuclear plant (Figure 2) from which freshwater could be continually pumped using HRS (pump located lake side).
> Pumping is variable, reliable, high flow (~600 GPM), and high pressure (potentially aiding in high pressure water injection into reactor cores).
> HRS water delivery system can be tied into existing fire hose systems that are being used on site to both inject water into cores as well as water spent fuel pools.
> For contingency of extended time in which nuclear plant unapproachable due to excessive hazard levels, freshwater pumping (and likely borate injection) from safe distance miles away could continue, preventing continued situation deterioration.
> HRS maker LaBarge Inc., as well as former GE chief of safety research Richard Lahey, agree with use of HRS high flow freshwater delivery from lakes.
Comments, suggestions?
  • hrspaper.pdf
    hrspaper.pdf
  • #1,077
Most of us are coming to the opinion that something worse than just venting on Reactor Three has happened. We still do not have enough evidence to convict.
  • #1,078
I agree thanks to all of you.
  • #1,079
The fresh water idea sounds essential and should have been actioned 10 days ago.
  • #1,081
Bodge said:
NHK WORLD:
That is as far as it could get before it died.
  • #1,082
A colleague indicated it was apparently unintended for the hydrogen and steam from containment to be vented into the secondary or upper containment (metal structure). He indicated that duct work to carry to the appropriate stack had ruptured, and the hydrogen leaked into the upper containment area. As far as I know, one would not design a system to vent H2 into the upper containment, precisely in order to prevent what did happen.
Salty seawater, which I expect has a fairly good soluble oxygen content, is problematic because it corrodes SS304. I imagine the intrusion produced a crud burst - crud being oxides of Fe, Cr, Ni, etc, and that could deposit on the fuel as it boils dry. Any crud on the fuel would be transportable in the seawater, which would explain the increase in Co-58,60 activity.
I'm curious about the behavior of UO2 oxidation in seawater. I'm not aware of any studies.
  • #1,083
Bodge said:
NHK WORLD:
That doesn't make much sense to me. The half-life is very short, and that of Ba-141 and La-141 is much longer.
The precursor Xe-141 has an even shorter half-life, so there shouldn't be any significant accumulation of Cs-141 outside of containment.
  • #1,084
I'm guessing this must have been a mistranslation. Cs-131 ?
  • #1,085
I was wondering about that, but I'm not sure.
Here's the radionuclides around Cs-131, 133. Xe-131 is stable, so any Cs-131 should be a direct fission product.
  • #1,086
In monitoring failed fuel, the industry typically measures Xe-133, Xe-135, Xe-138, Kr-85m, Kr-87 and Kr-88, and I-131,132,133,134,135.
Cs-134 and Cs-137 are also measured and the ratio can give some estimate of burnup.
Np-239 is measured and is an indicator for tramp fuel particles or released fuel from breached fuel rods.
  • #1,087
It's being reported that after one of the disasters (don't remember which one) the US forced reactor retrofits for hardened vents to avoid venting into the buildings, but it's a good chance the Japanese did not follow suit.
  • #1,088
Thanks. Yeah for better or worse fairly obvious ideas still need all the pieces to come together to emerge from the darkened idea space, and for disaster situations like this, that fact is scary.
  • #1,089
REGARDING THE PHOTOGRAPHIC EVIDENCE AND NATURE OF EXPLOSIONS, UNIT 1,3, 4
I am updating some of the earlier photo analysis that took place earler amongst the forum participants and that may not yet have been reviewed by those newer posters who have recently joined.
Look again, carefully, at the photos that AntonL referenced from Der Spiegel (page 23, post #363)
http://www.spiegel.de/images/image-193170-galleryV9-njkp.jpg
Reactor 4
http://www.spiegel.de/images/image-193230-galleryV9-ovfc.jpg
Reactor 4
Reactor 4
http://www.spiegel.de/images/image-193165-galleryV9-kzvg.jpg
Reactor 3
http://www.spiegel.de/images/image-193254-galleryV9-gmmj.jpg
Reactor 3 (corrected, original post says Reactor 1)
from MSNBC
http://msnbcmedia3.msn.com/j/MSNBC/Components/Photo/_new/110312-reactor-vlg-5p.grid-4x2.jpg
Reactor 1
I don't know how I missed this before, but here is what I think I see. The building designs and overhead cranes in 3 and 4 are different than in 1. The overhead cranes in 3 and 4 are mounted atop massive steal beams that run north-south, and that are supported, indeed have to be supported by the reinforced concrete columns on the east and west sides of the building. The weight and size of the beams that are the tracks for the crane, in turn, reinforce the bearing weight-bearing columns of the top floor of bldgs 3, 4.
The hydrogen explosion in the top floor of 4 spares most of the roof and all of the columns on the east and west sides because of this relationship to the construction and weight-bearing functions mentioned. After the explosion, you can see that the structural damage to the roof and most of the structural damage to the side walls of Bldg 4, are therefore most severe at the north and south ends of the building.
The same holds true for Bldg 3, except that
1) the explosion at Bldg 3 was much more powerful, and
2) the explosion at Bldg 3 results in the north wall weight-bearing columns buckling and the crane structure itself sliding or being blown off of the rails and falling from the top floor of Bldg 3 to the top of the smaller, adjoining building below on the north side of Bldg 3.
The fuel handling machenery (green) still sits atop the SFP of Bldg 4, but not at Bldg 3. The SFPs are at the southeast corner of both Bldg 3 and 4 as has already been confirmed.
The concrete panels between the structural weight bearing columns of Bldg 3, because of the much larger size and power of the blast in Bldg 3, resulted in the concrete panels between the weight bearing columns on the east and west sides becoming more effective "bullets" when they blew out en mass, from between the columns, doing the damage to the adjacent roofs of Turbine Bldg 3 and the building in back, on the west side of Bldg 3. The size and power of the blast also did much more damage to the superstructure of the roof girders of 3 than 4, but it would still appear that the roof girders over the drywall containment plug of Bldg 3 are not completely destroyed after the explosion. Hence, the drywall containment plug was not blow straight upward.
The annotated image below was modified from the original, at DigitalGlobe.com
The larger explosion at Bldg 3 is annotated. The short arrows are the paths of the "bullet-like" blow out of the east and west side panels of Bldg 3.
The long arrow shows the damage to the north-side structures adjacent to Bldg 3 done by the falling crane, visibly absent at Bldg 4.
The rectangles show the location of the highest rates of measured radioactivity, presumably at ground level, adjacent to Bldg 3, and taken from this Diagram, posted earlier by jlduh (#957), original reference not known.
http://www.monsterup.com/upload/1300925395929.jpg
This suggests to me, but it has not been confirmed, that the debris blasted from Unit 3 carried radioactive contaminants, either from the SFP or from the Unit 3 reactor core, or from both.
And this close-up of steam venting in the region of the SFP of Unit 3, I believe, reinforces the opinion (speculation on my part) that the containment of Unit 3, more specifically, the drywall containment at the location of the fuel transfer gate(s) and chute to the SFP is the source of the breech and the venting steam (diagram following).
This image of debris atop Bldg 3 suggests to some (myself included) that the blast displaced spent fuel rods from Unit 3's SFP, but this has not been confirmed.
  • #1,090
NHK reported that water in basement 3 has 10000 x the radioactivity as the water inside a normal operating reactor, hence the assumption that unit 3 containment may be breached, leaking water into basement 3.
This is the slide displayed while above was being reported.
This slide also confirms to me that the design parameter of a 5.7m Tsunami wave was an afterthought. The height as I in a previous mail suggested is determined by design need to keep basements above seawater levels as can be seen above That height dictates a maximum Tsunami wave such that pump cabins for coolant do not get destroyed. Ground level at reactor is about 15 metres as per earlier Tepco releases.
  • #1,091
Could one not just as easily conclude that the contamination comes from damaged fuel rods in the SFP with the leakage coming from the damaged SFP, or from dispersed fuel rods outside of the SFP that had been spayed with water over the last several days?
  • #1,092
Nobody has commented on my analysis, so I'll post it again. I was honestly startled.
  • #1,093
Makes more sense to me as water does not flow uphill - see basement levels of torus and turbine building of slide posted earlierTCups please note location of reactor relative to upper structure
  • #1,094
If the original data are correct and your analysis of the data is correct, then, the obvious comment is "gee, that is really hot!"
Do we know which were the source of the radionuclides emitting that level of radioactivity and how long their half lives are? If these represent the volatile components, brought to ground by rain or settling dust, for example I-131 with a half life of 8 days, then the radioactivity will be very different a few weeks from now. If, on the other hand, there are longer half-lived fission byproducts from the damaged fuel rods in the core or SFP, then the contamination will by its nature, be much worse and a much more long-lasting problem. Chernobyl was the later. As far as is yet know, Fukushima will be the former.
  • #1,095
The IAEA simply had this to say:
"Measurements will be taken to determine more precisely the actual radionuclides that have been deposited."
  • #1,096
What do you make of the fact that the exposure took place inside the turbine building that had debris smash through its roof after the explosion?
  • #1,097
I don't know for sure. On consideration, though, if the exposure were from pooled water in the building floor, it seems more likely that the contamination came in with the water, not from falling debris. That said, I believe there might have been rain there. Rain or sprayed water leaking through a large hole in the roof could easily be one route, if not the main rout for water accumulating in the building, versus, for example, ground water seepage from a crack in the foundation.
What do you think?
  • #1,098
What do you think?
I would guess that most of the water is still from the Tsunami, contaminated later.
  • #1,099
Exactly. It may be correct that "the sky is falling!", but it depends on what is in the sky that was the "fallout" that will determine whether or not it will be a long term problem. It's certainly not yet time to swallow the gun. :eek:
  • #1,100
Good point -- yes, there was that source of water, also. (:redface:)
49K
449K
274K
16K
11K
