Bending Stress Help: Find Resources Here
Bending stress calculations are essential for understanding the behavior of beams under load, particularly for I and T shapes with rectangular cross-sections. The discussion highlights a lack of textbook resources and an inaccessible animation provided by the professor. Participants are encouraged to seek alternative study materials, including books and online resources, to grasp the concepts of moment of inertia and stress types. The need for comprehensive resources on bending stress is emphasized. Engaging in further research will aid in mastering this topic.
kougou
Hello guys.
I need help to understand the calulation of bending stress. This topic is discussed in our lecture, and the prof shows us an animation for it. However, this topic is not on the textbook and the prof refuse to give us the link for the animation. I am wondering, do any of you know where could I find a good place to study for this topic. The current discussion is only limited to the moment of inertia, compression and tension stress, of the I, and T shape beams made up of rectangular cross -section.
Thank you all in advance!
Try looking through a few books or online.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
