Taylor series expansion for gravitational force
The discussion focuses on deriving a polynomial expression for gravitational force using a Taylor series expansion. The gravitational force formula is given as Fg = G*M*m/R^2, and the objective is to find the force at a height y much smaller than the Earth's radius R. The approach involves expanding the equation Fg = G*M*m/(R+y)^2 around y=0, leading to the expression R^-2(1 + y/R)^-2. Participants seek guidance on correctly setting up the Taylor series and utilizing resources like Wolfram Alpha for assistance. The goal is to achieve a first-order approximation of gravitational force at height y.
physics1311
The magnitude of the gravitational force exerted by the Earth on an object of mass m at the Earth's surface is
Fg = G*M*m/ R^2
where M and R are the mass and radius of the Earth.
Let's say the object is instead a height y << R above the surface of the Earth. Using a Taylor series or binomial expansion, find a polynomial expression in y for the force of gravity acting on this object, correct to first order (i.e., in this case, the lowest "non-trivial" order of the Taylor series).
taylor series equation
I set up the equation as Fg=G*M*m/(R+y)^2 centered around y=0
I'm just lost on how to set this up, what is the right equation and point to center around?
(R+y)^-2 = R^-2(1 + y/R)^-2 Expand this about y = 0
Using as input "R^-2(1 + y/R)^-2"
In the following link, you may need a free plugin,
http://www.wolframalpha.com/input/?i=R^-2%281+%2B+y%2FR%29^-2&cdf=1
See series expansion in the above link.
Thanks for the help
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
