Comparing pressure loss to Blasius
  • Thread starter Thread starter Isabella F
    Loss Pressure
The discussion centers on comparing pressure loss in a turbulent pipe flow simulation to the Blasius and Darcy-Weisbach equations. The user has conducted a CFD simulation and obtained a straight negative gradient for static pressure versus distance. It is noted that the Blasius equation is not suitable for turbulent pipe flow, while the Darcy-Weisbach equation is appropriate for this scenario. The conversation emphasizes calculating the friction factor from the pressure drop and using it alongside the Darcy-Weisbach equation to estimate theoretical pressure loss for comparison. Overall, the focus is on applying the correct equations for accurate analysis of pressure loss in turbulent flow.
Isabella F
Hi everyone. i have done a CFD smulation in fluent for a turbulent pipe flow and have plotted static pressure against distance x. from the graph i get a straight negtive gradient. i have been told that you should compare the pressure loss to Blasius equation and Darcy equation. How do i compare the pressure loss to this. thank you. the fluid is water, diameter is 50mm, inlet velocity is 1m/s and reynolds number 49760.
heres is the xy plot i get.
Well that seems awfully silly to compare to Blasius because (A) it is pipe flow, so Blasius is not representative, and (B) it is turbulent, so Blasius doesn't apply.
Comparing to Darcy-Weisbach should be straightforward though.
The Blasius friction factor f=0.079/(Re^0.25).
Is there a way to calculate friction factor from the presure drop? that is what i think i need to do and then compare to blasius friction.
Ah, I thought you were referring to the Blasius boundary layer. My mistake.
How do i do this then. I am a bit confused.
Just look up the Darcy-Weisbach equation. It is very straightforward. Use it and the Blasius correlations to approximate the theoretical pressure loss (head loss) and compare to your results.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
