Fibonacci sequence- advanced realations
  • Thread starter Thread starter Rocketboy123
    advanced Sequence
Rocketboy123
My main interest is usually physics, however I have become interested in the Fibonacci sequence. I looked at the sequence in detail and found a few interesting patterns. The main pattern was a relationship of the way that the digits of numbers compounded, the exact pattern was: 7,5,5,4,5,5... (that repeated). An easier way to explain it is that there are 7 single digit numbers, 5 double digit numbers, five triple digit numbers, 4 quadruple digit numbers etc. I was wondering if this was a mere coincidence (which is rare with Fibonacci numbers)or if it was relevant, and hopefully not pre-discovered (I thought I discovered Pascal's Triangle until i learned Blaise had beaten me by a couple hundred years...).
Well the Pascal triangle was known well before Pascal was born.
I strongly doubt there is a repeating pattern in that sequence you mention, which btw starts like this 7,5,5,4,5,5,5,4,5,5,5,5,4,5,5,5,5,4,5,5,5,4,5,5,5,5,4,..
The sequence reflects the fact that the ratio between successive fibonaccis quickly approach the golden ratio \varphi=(1+√5)/2, so that (log10\varphi)-1= 4.784.. becomes the average number in the sequence. Any repeating pattern depends on that last number being rational, which, uhm.. lacking something better to say, is unlikely.
In general, Rocketboy123,
You might want to familiarize yourself with the properties of Lucas Sequences (not "Lucas Numbers"). It will save you many headaches later on.
- AC
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
