Best way to test web based programs without a server?
To test web-based programs like PHP and MySQL for a website without the hassle of FTP, installing Apache, PHP, and MySQL on a Linux Mint laptop is recommended. This setup allows for local server access via URLs such as http://localhost. A tutorial is available to guide through the installation process. Running the client and server on the same machine is generally acceptable, but developers should be aware that local testing may not replicate all conditions of a live environment. It's advised to avoid hardcoding references to localhost in the code and to use relative URLs to facilitate easier transitions between local and production servers.
rollcast
I need to test some web based programs, eg. PHP, MySQL, for my dads website but I can't be bothered having to ftp the server everytime I make a slight change to the settings.
Is there anyway I could maybe simulate the server and the website on my laptop? I'm running Linux Mint if that's anyhelp.
Thanks
A.
Technology news on Phys.org
Install Apache, PHP and MySQL on your laptop. They might even be there already, as part of your Linux distribution.
Then you'll have your own sever that you can access in a browser with URLs like http://localhost/blahblah .
This tutorial looks like just the thing for you:
http://community.linuxmint.com/tutorial/view/486
Thanks I'm working throught the tutorial now.
Will it matter that I'm running the client and server from the same machine when I'm testing it?
It shouldn't matter. The most likely problem is going to be that your local client won't have as many restrictions. Some things can work when you test locally can break when they're uploaded and used by a real client. Also, be careful with putting references to localhost in your code.
Using relative URLs in your code simplifies moving your stuff back and forth between your computer and your production server.
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
