How to Find a Unit Vector Perpendicular to Another in the XY Plane?
To find a unit vector in the XY plane perpendicular to A = (3,5,1), the dot product A·B must equal zero, leading to the equation 0 = 3B_x + 5B_y. Since B is constrained to the XY plane, B_z is not considered. A suggested unit vector is (1/√34)(-5i + 3j) or equivalently (1/√34)(5i - 3j). The discussion also emphasizes that for B to be a unit vector, the condition B·B = 1 must hold true in component form.
PhizKid
Find a unit vector in the xy plane which is perpendicular to A = (3,5,1).
<br /> A_x{B_{x}} + A_y{B_{y}} + A_z{B_{z}} = \textbf{A} \cdot \textbf{B}\\\hat{\textbf{A}} = \frac{\textbf{A}}{|\textbf{A}|}<br />
In order to be perpendicular, AB = 0 since a perpendicular 90 degrees would mean cos(90) = 0, so the entire dot product becomes 0.
So:
\textbf{A} \cdot \textbf{B} = 3{B_{x}} + 5{B_{y}} + 1{B_{z}}
But since B doesn't exist on the z plane:
So:
0 = 3{B_{x}} + 5{B_{y}}
Not sure what to do from here. Using:
\hat{\textbf{B}} = \frac{\textbf{B}}{|\textbf{B}|}
How would I turn this B vector into a unit vector?
So:
So:
How do you get |B| from the components?
ehild
you can take (1/√34)(-5i+3j) as your unit vector.
edit-or also 5i-3j in place of -5i+3j.
So:
So:
If B is a unit vector, then B dotted with B has to be 1. What does this mean in component form?
Thread 'Correct statement about a reservoir with outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
