Trouble finding the integral for volume
  • Thread starter Thread starter Pseudo Statistic
    Integral Volume
The discussion focuses on finding the correct integral for calculating volume problems related to the area between the functions y=x+1 and y=x^2-1. The difference between these functions, which determines the side length of the squares, is established as x - x^2 + 2, valid between x=-1 and x=2. To find the total volume, the area of the square is integrated over this interval, leading to the integral A(x) = ∫ from -1 to 2 of (2x - x^2 + 2) dx. Additionally, for another problem, the area of a cross-sectional rectangle is simplified to x - x^2 + 2, making it easier to evaluate. The thread seeks further assistance on related volume questions.
Pseudo Statistic
I'm having trouble finding the integral I'm supposed to use for some Volume problems...
Can someone lead me in the direction as to how I should form my integrals to get the solutions?
The below is a scanned page from an AP Calculus textbook, I'm pretty much stumped on how to solve 56-59..
Hope someone can help.
Thanks.
http://www.brokendream.net/xh4/apcalcscan.jpg
I'll give you some hints on the first one (56a). They're all pretty much the same. The side of the squares are determined by the difference between the two functions y=x+1 and y=x^2-1. This difference is x-x^2+2, it is zero for x=-1 and x=2. So now you have determined the shape of your base.
With this you can easily find the area of such a square. Integrating over x gives you the total volume.
OK, so you merely evaluate the integral A (x) = \int_{-1}^\2 2 x - x^{2} + 2 dx?
Does anybody have a clue about the other questions?
Thanks.
Well, if you want to evalute the area enclosed by the two lines (y=..) yes, but...
Thanks.
x - x^2+2 gives the length of one side of the square as a function of x. You need the area of the square.
b) Is somewhat easier, since the height of each rectangle is one, that means the area of a cross sectional rectangle is x-x^2+2.
