Done by parts integral and simplify
The discussion focuses on integrating the function (x^2)(e^x)dx/((x+2)^2) using integration by parts. Participants suggest simplifying the integral by letting u = (x^2)(e^x) and dv = 1/((x+2)^2). The process involves differentiating u to find du and integrating dv to find v. The integration by parts formula is then applied, leading to a simplified integral. Overall, the method effectively simplifies the integration process.
Yegor
i have to integrate the next:
It should be done by parts.
How I can simplify it?
Is (4x+4) (e^x) dx/(x+2)^2 easier to be integrated?
the easiest way to do this is by parts.
let u=(x^2)(e^x)
let dv = 1/(x+2)^2
get du by differentiating u by x
get v by integrating dv in terms of x
then write out u*v - integral(v*du)
the integral simplifies pretty nicely.
Thank You a lot!
