Charging by conduction with and odd net charge?
When two conducting spheres, A (neutral) and B (charged -3e), touch, charge redistribution occurs, but they cannot have fractional charges. The total charge of the system is conserved, so the charge will distribute in a way that maintains the overall charge balance. The movement of electrons during contact is influenced by thermal randomness, meaning that one electron may transfer to the neutral sphere, but it is uncertain how many will move. Typically, it is suggested that two electrons may stay on the charged sphere while one moves to the neutral one. This process highlights the principles of charge conservation and electron mobility in conductive materials.
Legaldose
Hello, I've just got a quick question about charging an object by conduction. I've been studying for my final and I came across a problem that I can't really see how to solve.
Say you have two conducting spheres, A and B. They are both exactly the same in every way except for their electric charge. Say A is electrically neutral and B has a charge of -3e. Now what happens when they touch? I was under the impression that when they come into contact they would share the charge equally, but you can't have a charge of -(3/2)e. So what happens?
Thanks, and happy physics!
Small numbers like that aren't realistic, but I'm pretty sure it would be random which sphere the one extra electron would end up on. Think thermal randomness...
one would think the three electrons were initially equidistant from each other on the one sphere. Touching the spheres together would enable at least one of the electrons to move to the second sphere...so I like the 'random' explanation already provided. But an argument might be made that in most cases, two would remain on the initial sphere.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
