Mercury Manometer: Explaining Pressure Changes
  • Thread starter Thread starter Bengo
    Manometer Mercury
The discussion centers on the functioning of a mercury manometer in measuring pressure changes during a reaction. It explains that one side of the U-tube is open to air while the other is connected to a reaction system. The derived equation ΔP=ρgΔh equates the upward force from the gas pressure to the downward force of gravity. A key point raised is the omission of atmospheric pressure in the calculations. It is clarified that atmospheric pressure was accounted for during calibration before the reaction, effectively balancing it with the initial gas pressure. Therefore, the focus remains on the pressure change due to the reaction itself. For absolute pressure measurements, atmospheric pressure would need to be included, necessitating a specific calibration of the manometer.
Bengo
In my book it talks about a mercury manometer where one side of the U tube is open to air and the other side is connected to a system where a reaction takes place. It then derives ΔP=ρgΔh by setting the force pushing the mercury up equal to the force pushing the mercury down. The force pushing the mercury up is the pressure of the gas from the system multiplied by the cross sectional area of the mercury which is F=PA. The force pushing the mercury down is gravity, F=mg. My question is why don't they consider the atmospheric pressure pushing down on the mercury since one side of the manometer is open to the air?
Thank you! You guys have been so helpful!
Chemistry news on Phys.org
You are interested in the change in pressure caused by the reaction.
Presumably the gas was at some pressure before the reaction and you calibrated the manometer before the reaction took place. Therefore the atmospheric pressure was already balanced by the pressure that the gas exerted before the reaction.
Once the reaction occurs you get the change in pressure caused by the reaction only, which is all you are interested in. The atmospheric pressure has already canceled out with the gas pressure before the reaction.
Now if you wanted to know the absolute pressure in the system then I agree you would have to add atmospheric pressure to the equation. But you would also have to calibrate your manometer to read -1atm when the system was a vacuum (i.e. P=0).
Likes 1 person
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
