Temperature and Mass Flow effect on Pressure
The discussion focuses on modeling the pressurization of air in a constant volume tank using a pressure regulator, emphasizing the relationship between pressure, mass, and temperature. The ideal gas law (PV=nRT) indicates that pressure increases can result from either mass or temperature changes. The main inquiry is how to quantify the contributions of mass flow and temperature increase to overall pressure changes. It is noted that for adiabatic conditions, isentropic relations can be applied, allowing for predictions of temperature changes with pressure increases. The equations discussed are applicable to both closed and open systems, despite initial concerns about their relevance in an open system where mass flow is involved.
samshree
Hello,
I am trying to create a theoretical model of pressurizing air in a constant volume tank to a pre-set pressure. We are increasing the pressure using a standard pressure regulator. From the equation PV=nRT I know that an increase in pressure at a constant volume can result from an increase in mass and/or temperature. In our model I believe the main source of pressure increase is due to mass increase, but I have experienced and increase of temperature due to recompression as well. Is there a way to determine how much of the pressure increase is due to mass flow and how much is due to temperature increase? And is there an equation or model I could use to predict how much the temperature of the gas will increase when the pressure increases a certain amount?
There are models for this, particularly if you can ensure the tank is adiabatic (no heat transfer in or out of the tank). In that case you can treat the problem as isentropic and use the ideal gas law and the isentropic relations to get what you are after. For example, you know one form of the ideal gas law is ##p = \rho R T## where ##R## is the specific gas constant. For an isentropic process in an ideal gas, you have the following relationships:
$$\dfrac{p_2}{p_1} = \left(\dfrac{\rho_2}{\rho_1}\right)^{\gamma} = \left(\dfrac{T_2}{T_1}\right)^{\gamma/(\gamma-1)}$$
where ##\gamma = c_p/c_v##. That should get you where you need to go.
Will this still apply to an open system where mass is flowing into the control volume? The temperature and density are changing simultaneously. I have seen these equations before but I thought they were for a closed system
No it still works.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
