Calculating the radius of a nucleus of a Pd-118 atom
To calculate the radius of a Pd-118 nucleus, the relationship between the radius of the nucleus (R) and the number of nucleons (N) is established as R = (1.3 x 10^-15 m)N^(1/3). Given that Pd-118 has 118 nucleons, substituting N into the formula yields R = (1.3 x 10^-15 m)(118)^(1/3). The calculations involve simplifying the equation and ensuring correct substitutions for variables. The discussion highlights confusion in the calculations leading to an incorrect answer, prompting a request for clarification on the methodology.
Lt.Saccharine
Here is the question I am attempting to solve :
A proton or neutron has a radius r of roughly 110-15 m, and a nucleus is a tightly packed collection of nucleons. Therefore the volume of the nucleus, (4/3)R3, is approximately equal to the volume of one nucleon, (4/3)r3, times the number N of nucleons in the nucleus: (4/3)R3 = N(4/3)r3. So the radius R of a nucleus is about N1/3 times the radius r of one nucleon. More precisely, experiments show that the radius of a nucleus containing N nucleons is (1.310-15 m)N1/3. What is the radius of a palladium nucleus
So, in order to arrive at an answer I listed variables ,constants and equations that were known:
4/3*pi*R^3=4/3*pi*r^3*N
R= (N^1/3)*r
N=(1.3e-15)* (N^1/3)
r=1.0e-15
and so, in order decrease the number of variables given , I plugged in variables into variables:
R=(N^1/3)*r ---> R/r =(N^1/3)
N=(1.3e-15) * (N^1/3) ---> N=(1.3e-15)*R/r
so I substituted the new expression for N into:
4/3*pi*r^3 =4/3*pi*R^3 * N ----> 4/3*pi*r^3= 4/3*pi*R^3*((1.3e-15)*R/r):
pi and 4/3 cancel , show I should be left with:
r^4/(1.3e-15) = R
since r = 1e-15 , then R should equal :
(1e-15)^4/(1.3e-15)=R
And my answer is no where near the actually answer : Can you tell me what I am doing wrong
So wouldn't the radius of the Pd-118 would be 1.31e-15 * N^{1/3} where N is the number of nucleons in the Pd-118 nucleus?
AM
