What is the mechanism behind airport shopping trolley brakes?
  • Thread starter Thread starter Bladibla
Airport shopping trolleys typically utilize a simple braking mechanism that operates through friction, often resembling systems found in walkers or wheelchairs. These brakes may consist of a rubber-coated steel bar that presses against the tire or a lever system similar to a hand brake in cars. The service carts used on planes employ a lever-type brake where one lever locks the brake and another releases it. Some trolleys may use a rod-operated brake that clamps the wheel with rubber discs. Overall, the braking systems are designed to be straightforward and effective, prioritizing functionality over complexity.
Bladibla
Hi there.
What is the braking mechanism called used in trolleys/ especially in airport trolleys where you pull the handle to stop the wheels? And how does it work?
Cheers
I'm afraid that I've never seen one, so I don't know. It's unlikely, however, that they use anything exotic like calipers or brake drums. On 'walkers' for the elderly, or wheelchairs, it's generally just a rubber-coated steel bar that gets pulled against the tire.
A brake mechanism works by friction. If they have brakes, it may be a leaver system, much like a hand brake in a car. The service carts on planes have a lever type brake system. One lever is pressed to lock the brake on, and another lever is pressed to release the brake.
I have not seen what you are referring to. However, I would think that it would be something similar to what you see in a bicycle.
The ones I've seen are just a simple rod-operated brake which clamps the wheel from both sides by two circular rubber discs. You don't really need the progressive control you have with a car or a bike, they're pretty crude, clunky, and on/off.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
